18 volts?? eecks!
Old Jan 26, 2007 | 11:10 AM
Gazpar's Avatar
Gazpar
Default 18 volts?? eecks!
My 86 has started an odd problem...
Sometimes my vette will spike up to 17-18 volts. It drops back down shortly to the "normal" 13.5 ish.
(as a side note, my headlights wont pop "up" all the time. I have to play with the switch for them to work.) The lights come on, just not raise
Im working off the assumption that my voltage regulator (in my alt) is shot, and that the headlight issue may be a bad relay caused by a spike. No fuses are blown.
any thoughts?
Old Jan 26, 2007 | 02:07 PM
Chapindad's Avatar
Chapindad
I think that is a good assumption. IMHO: I would get the Altenator replaced quickly because 18 volts could do some damage to senistive systems.
Old Jan 26, 2007 | 02:44 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
On my 95 there's two fusible links. If one blows, you don't have enough volts. If the other one blows, you have too much. Check them as well and make sure they're not on the way out. They're slow blow so they don't go out all at once.
Old Jan 26, 2007 | 03:06 PM
Gazpar's Avatar
Gazpar
Good Info!! ty
Where are the links at?
Old Jan 26, 2007 | 03:28 PM
jfb's Avatar
jfb
There are no fuses that one blowing causes low voltage (it could cause zero volts) and another blowing causing high voltage out of the alternator!!!!!!!!! You have a defective voltage regulator in your alternator and I wouldn't run the engine until you replace the voltage regulator (inside the alternator) or get another alternator. 18 volts can damage the ECM, dash cluster, radio, and a bunch of other of your electronics in the car. GM allows up to 16.0 volts out of the alternator.
Old Jan 26, 2007 | 03:34 PM
Keystring's Avatar
Keystring
There are two diodes in the regulator. If one diode 'opens' then you will have a low voltage condition.
On the other hand if one diode 'shorts' you will have a high voltage condition.
It would be like replacing one of the diodes with a solid piece of wire.
Old Jan 26, 2007 | 04:00 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
do not drive it till it is fixed!!!
the risk outweigh the rewards
Old Jan 27, 2007 | 07:28 AM
larryfs's Avatar
larryfs
soon, you'll be replacing every light buld in the car, dash lights, interior lights, cluster lights, everything.
The ECM should have an internal voltage regulator, but there definately is an upper limit.
Old Jan 27, 2007 | 09:38 AM
Gazpar's Avatar
Gazpar
Thanks for all the good info...
For the record, It hasnt been driven since the prob started.
Im looking to use this as an oppurtunity to upgrade the alternator.
Thanks again, and Ill keep everyone posted
To 18 volts?? eecks!
