Need advice. Removing Diff fluid
Old Jan 26, 2007 | 08:42 PM
slicked25's Avatar
slicked25
Default Need advice. Removing Diff fluid
I'm currentley in the process of removing differential fluid and I removed the fill plug then removed the draing plug. When I removed the draing plug but NO oil came out at all. Granted the car is not warmed up but this thing may be dry. Couldn't get any out with the pump either. I'll let it warm up and see if that loosens the oil up but this is all new to me.
Old Jan 26, 2007 | 09:22 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Well, there is a pretty good discussion going on about this here:
http://forums.corvetteforum.com/show....php?t=1604208
Old Jan 26, 2007 | 09:24 PM
JackDidley's Avatar
JackDidley
Are you sure you removed a drain plug ? The car did not come with one. Some guys do add one, but if thats not the case you may have just removed one of the cover bolts.
Old Jan 26, 2007 | 09:56 PM
aminnich's Avatar
aminnich
Hope that is all that there is to it. Feed a piece of small rope in the fill hole and pull it back out--wet would be good, dry, well let us not think about that. Good Luck.
ps--get a cheap siphon gun to suck the old fluid out of there.
Old Jan 26, 2007 | 10:02 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Try here:
http://www.c4guru.com/articles/Chang...ntialFluid.pdf
Old Jan 26, 2007 | 10:08 PM
slicked25's Avatar
slicked25
Well if this is not the drain plug then it will not surprise me? I gave up. I don't have the right vac. I need the Mity Vac but my Sears had never heard of that before even though it's listed on the stores website. I even tried a freaking turkey baster but gravity was a mother so I quit until I get the right vac.
Scroll down to figure 5. That's the drain plug that I removed but nothing ever came out of it.
http://www.autozone.com/servlet/UiBr...3d802128ac.jsp
Old Jan 26, 2007 | 10:16 PM
JackDidley's Avatar
JackDidley
Yep, thats just a cover bolt. You can get a suction gun at a real parts store. It works like a big syringe with a hose on the end.
Old Jan 26, 2007 | 10:19 PM
aminnich's Avatar
aminnich
Bet you are glad to hear that. Drive it around a bit to get the fluid hot and stirred up before you suck it out. Makes it easier to do.
Old Jan 26, 2007 | 10:23 PM
slicked25's Avatar
slicked25
By looking into the drain plug in the pic in fig. 5 I could see liquid stuff but the that screw that was about 1 1/4 long was dry on the tip fwiw.
Old Jan 26, 2007 | 10:29 PM
JackDidley's Avatar
JackDidley
If it was leaking you would have noticed. Gear oil stinks when it gets on the pipes and burns. I should warn you. The job is messy. Its hard to get to the filler hole with the hose without dripping some. Did I mention ger oil stinks ??
(what you saw in the hole was probably silicone. No gasket on the cover)
Old Jan 26, 2007 | 10:39 PM
slicked25's Avatar
slicked25
Chilton's makes it look so easy a cave man could do it. Whatever's in Chilton's is the same pictures that's on Autozone.com. I'm just curious what that plug was. Nothing like being worn out and frustrated. After getting the oil all over my hands that's when I gave up until I get the right tools. But I didn't mention when I first removed both plugs and lowered the car back on all fours a small amount of gear oil leaked out of the fill plug hole. So I guess it's not bone dry.
There was some thread sealer on the so called drain plug screw.
Old Jan 27, 2007 | 12:12 AM
bogus's Avatar
bogus
I might as well post this...
C4 Guru - Changing Differential Fluid.
Old Jan 27, 2007 | 07:45 AM
Billy Stargazer's Avatar
Billy Stargazer
Bogus; Thank you for the great and informative article. I have printed it off for future reference. Thanks again! You are a wealth of information.
Old Jan 27, 2007 | 09:48 AM
Doug 87L98's Avatar
Doug 87L98
I need to change mine also and that article by you will be a great help. Thanks for posting.
To Need advice. Removing Diff fluid
