Help with shifter.
Old Jan 30, 2007 | 01:01 PM
93gtguy's Avatar
93gtguy
Default Help with shifter.
I'm a new corvette owner. I have a 6 speed transmission and would like to change the shift ****. What thread size is my C4 and is the C5 and C6 shifters the same? I've been through posts of shift ***** but most of them are for the newer vettes. Any help is appreciated.
Thanks,
Casey
Old Jan 30, 2007 | 01:48 PM
JH23's Avatar
JH23
if i aint mistaken (which i may be)...but i think you pop the top off the shifter...the part that has the numbers on it...there is as pin in there you have to pull out...it should be very easy to do now since the tranny was replaced a few months back....pull that pin out....stick your new **** on and putthe pin back in...if i'm right
Jamie
Old Jan 30, 2007 | 01:51 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
The C5 shift **** has the same threads as the C4. Don't know for sure about the C6.
Larry
code5coupe
Old Jan 30, 2007 | 03:03 PM
93gtguy's Avatar
93gtguy
Larry
code5coupe
Thanks Larry, I thought the C4 & 5 were the same. I just wanted to make sure before I bought one.
Casey
To Help with shifter.
