starting issues
Old Feb 1, 2007 | 10:30 AM
pablo84's Avatar
pablo84
Default starting issues
My 84, will start nine times out of ten and then will not start. This is usually when the engine is warm. I will shoot some ether in throttle body, where injectors are and it starts right up. I have replaced injectors, starter, dist, wires etc. Any ideas?? Thanks for your help.
Old Feb 1, 2007 | 10:39 AM
not08crmanymore's Avatar
not08crmanymore
Is it cranking but not starting??
If so,might be the crank sensor.
Old Feb 1, 2007 | 11:01 AM
pablo84's Avatar
pablo84
It cranks, but injectors are not putting fuel to carbs. I spray ether and it starts right up??
Old Feb 1, 2007 | 11:14 AM
not08crmanymore
No clue,then.sorry.I know if it cranks but doesn't start,the sensor is bad.
Could it be the fuel pump??If the fuel pump is bad or going bad,it'll crap out occasionally till it dies all together.
Old Feb 1, 2007 | 11:43 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Sounds like a fuel delivery problem. Either the fuel pump is going bad or it's a relay. Have you changed the fuel filter? Were the new injectors installed properly?
Old Feb 1, 2007 | 12:19 PM
94z07fx3's Avatar
94z07fx3
One more thing to check:
On a 1984, if the oil pressure switch is inop or there really is low pressure will that kill the fuel pump relay?
Old Feb 1, 2007 | 12:29 PM
pablo84's Avatar
pablo84
Fuel filter has been replaced and injectors made a subtle improvement in performance.
Old Feb 1, 2007 | 01:40 PM
not08crmanymore
well,if it craps out all together,i'd say look at the fuel pump.If you have any back issues of vette magazine or corvette fever,I think they went over this very issue a while ago.
Old Feb 1, 2007 | 02:57 PM
pablo84's Avatar
pablo84
I'll check into pump..Thanks for your help.
Old Feb 1, 2007 | 03:10 PM
not08crmanymore
good luck!Let us know what it turns out to be.
Old Feb 1, 2007 | 06:36 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
it was an oil pressure relay on mine that caused it... but it may also be that the pump cant get it there without help
To starting issues
