Ac Problems Help Please
Old Feb 19, 2007 | 09:09 PM
imdaking06's Avatar
imdaking06
Default Ac Problems Help Please
Hey guys my 91 corvettes ac was working fine a couple days ago but now when i turn the car on the light is blinkin when i press the auto button for my ac i dont know what is wrong any suggestions on what could be the problem?
Old Feb 19, 2007 | 09:21 PM
scranage's Avatar
scranage
Most likely low freon.
Old Feb 19, 2007 | 11:12 PM
93*Corvette's Avatar
93*Corvette
Run the diagnostic on the AC system. Takes about 2 minutes... Hopefully yours is a C68 AC...
http://www.idavette.net/tech/c4diag.htm
Old Feb 19, 2007 | 11:20 PM
Tommy T-Bone's Avatar
Tommy T-Bone
St. Jude Donor '06-'07-'10-'11-'12-'13-'14
Worth looking into. You can get a recharge kit and check the pressure on the low side. I had to disconnect the battery to clear the codes and jump my compressor to take the charge.
Old Feb 20, 2007 | 08:10 PM
scranage's Avatar
scranage
It's R12 up to 93. Can't get the recharge kit unless you take the EPA test and get the card. But that's not too hard, I got mine last year.
Old Feb 20, 2007 | 08:22 PM
SunCr's Avatar
SunCr
Post your diagnostic results if you need further help. If it's out of gas, best to fix the leak and to put some more oil in it before you fry the compressor. I'd at least replace the Accumulator and dump 4 ozs of oil (8 ozs is system capacity) in a new one whether or not you fix any leak. You can verify that it's not leaking at the compressor shaft seal by checking for oil on the hood above it.
Get your license for R12 at www.epatest.com or any of the sites listed at www.epa.gov - you also need the right tools to do the job: a manifold gage set and a vacuum pump (to suck the air out of it if you open it up).
Old Feb 24, 2007 | 10:49 PM
Desert1957's Avatar
Desert1957
Default same problem
Desert
To Ac Problems Help Please
