Help with CCM codes
Old Feb 27, 2007 | 03:22 PM
HG's Avatar
HG
Default Help with CCM codes
1993 coupe
Finally pulled the codes from the CCM to see what was making SYS flash. In module 1, the codes C13, H13, and H 74 flashed. In module 4 & 9 , just three - - - came up which means no codes. I found some info for C13 DIC switches open or shorted, but don’t know what H13 & H74 indicate. Any help.
Old Feb 27, 2007 | 03:59 PM
SunCr's Avatar
SunCr
I don't, but generally anything with an H means it's History and it's no longer a problem. Clear memory and see what comes up with a C or Current.
Old Feb 27, 2007 | 04:15 PM
HG's Avatar
HG
thanks, I forgot about the C & H. I can't clear the codes using the buttons as described in the book, so I disconnected the battery for 5 minutes. It now has C13 & H 13. THe H74 is gone. 74 is the LED display dimming output circuit open or shorted to ground. I've been shopping around on Ebay in hopes to find the trip monitor switch / buttons.
Old Feb 27, 2007 | 05:00 PM
Gixster's Avatar
Gixster
This thread should help.
http://forums.corvetteforum.com/show....php?t=1439826
It appears that you have an oxygen sensor issue with the C13. The 74 code is typically related to installation of an aftermarket stereo. It can be remedied if you do have an aftermarket stereo though. If you don't, I'm not sure what's causing that particular code.
Old Feb 27, 2007 | 05:04 PM
HG's Avatar
HG
These codes are taken while in module 1, which is the CCM, not the ECM
Old Feb 27, 2007 | 08:33 PM
Gixster's Avatar
Gixster
Gotcha. Sorry about that. I missed that part earlier. I'm at home now and just dug out my FSM.
If you want the info regarding troubleshooting the C13 code, let me know and I'll send you a copy of the page out of my service manual. I don't have a scanner at the house, so I'd have to take a picture and send that to you. If you think it'll help let me know and I'll do that for you.
Old Feb 27, 2007 | 08:44 PM
HG's Avatar
HG
I just found the complete unit on ebay. Hopefully, I can get it cheap. I do have a factory manual. But thanks. THe problem is intermitten, but is a P I T A
Old Feb 27, 2007 | 09:17 PM
bogus's Avatar
bogus
C4 Guru - Reading CCM Codes 1992/1993
Old Feb 27, 2007 | 09:24 PM
HG's Avatar
HG
Originally Posted by bogus
Thanks, I had that and that's how I found out the codes and procedure. I just won the complete DIC with trip monitor on ebay. Hopefully, this will stop the problem
To Help with CCM codes
