Horn Difference
Old Feb 27, 2007 | 11:50 PM
zmanz1's Avatar
zmanz1
Default Horn Difference
my passinger side horn is out , can anyone tell me when i replace it are both horns the same sound or are they different part #s,thanks
Old Feb 28, 2007 | 12:18 AM
TRace8893's Avatar
TRace8893
There is a high and a low horn. So yes, two different horns. (My driver's side horn was out and it sounded absolutely pitiful without both horns.) I do have an extra passenger side horn off of a '93 if you're interested.
Old Feb 28, 2007 | 12:39 AM
nosgsxr's Avatar
nosgsxr
how much u want 4 it.....if he dont get it i need one.....you cant even here my horn if the car is moving....
Old Feb 28, 2007 | 12:46 AM
bob howard's Avatar
bob howard
my drivers side horn was out when I bought mine. Contact Jason at vette2vette.com he has them.
Old Feb 28, 2007 | 10:20 AM
m_r_donovan's Avatar
m_r_donovan
Default Horn problem
This is an unrelated horn question. I just got a 1990. The horn was unpluged. It will go constantly when pluged in. Where should I start?
Old Feb 28, 2007 | 10:39 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Start by unplugging the horn.
Then, take the steering wheel apart and check the horn contacts.
You may have a stuck horn relay, but that's a long shot...........
Larry
code5coupe
Old Feb 28, 2007 | 10:06 PM
Mike_88Z51's Avatar
Mike_88Z51
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
When I first got my Vette the horns sounded pitiful. I thought that either the relay was bad, or the horns were cheap aftermarket replacements by the previous owner. The relay checked out as good and the horns were the original factory units. When I went to remove them to take them to an auto-parts place for louder replacements, I noticed that there was a small silver adjustment **** sticking out the back side. The **** appeared to be frozen in place due to some corrosion. I figured I had nothing to lose by breaking the **** on an already "broken" horn, so I used a small Vise-grip and twisted the **** about 1-1/2 turns; then reconnected the horn. It was MUCH louder! I kept twisting and tweaking it until it was as loud as possible with the tone I liked best. I remounted the horn, but left it disconnected and went to work tweaking the horn on the other side unitil it was as loud as possible. I then reconnectd the first side, and both horns have worked fine ever since.
Old Mar 1, 2007 | 07:12 PM
lt4red's Avatar
lt4red
The horns will have letters on them, one is f and one a if i remember correctly and this correlates to the tone they emit.
Old Mar 1, 2007 | 07:44 PM
tlong's Avatar
tlong
Identical replacements are at any auto parts place that are twice as loud. They are A and F tone. I love punishing errant and askew drivers whereas previously it sounded like a Barbi Vette.
Old Mar 2, 2007 | 11:03 AM
SOF Vette's Avatar
SOF Vette
Good info folks....continueing in the "tone" of this thread
My drivers side horn only works when the OEM alarm goes off.
THoughts?
Thanks!
SOF Vette
Old Mar 2, 2007 | 11:33 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
It could also be a grounded or bad horn relay. On my 1989 it is behind the dash info display!
To Horn Difference
