LTx Computers - do they interchange
Old Mar 6, 2007 | 11:36 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
Default LTx Computers - do they interchange
I'm looking at having a computer reflashed and would like retain my stock computer. Do I specifically need a computer for the LT4 out of a vette or would a computer out of an F-body, Caprice, Buick Fleetwood, ect. work just as well?
Old Mar 7, 2007 | 12:57 AM
bogus's Avatar
bogus
stick to your stock PCM. It has to be able to interface with the CCM... without that, you loose IP and ABS/ASR.
Old Mar 7, 2007 | 08:43 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Download and keep the original .bin file and if you want to go back, simply flash the original file straight back on. It will be like as if you never replaced it.
Old Mar 7, 2007 | 09:42 AM
kwik_ta's Avatar
kwik_ta
Good info!!!
How would I go about doing that? Forgive me... I'm OBDII stupid
Old Mar 7, 2007 | 10:03 AM
Casethecorvetteman
Ive never looked into it for a 96, but LT1 edit is one way, and i think Tuner Cat is available for the OBD2 vehicles as well, ill see if i can find it.
Old Mar 7, 2007 | 10:16 AM
Casethecorvetteman
Ok, here is some info ive dug up for ya, it seems the TunerCat OBD2 version has been bought by JET;
Originally Posted by JET website
Stock programming from the vehicle is initially downloaded and saved to your PC using the supplied JET interface cable that connects to the vehicle’s diagnostic port. The stock programming can be reloaded to the computer at any time to return the vehicle’s ECU to its original state.
Try this link: http://www.jetchip.com/products.asp?...&model=440#440
And also here: http://www.ls1.com/forums/archive/in...p/t-31534.html
Old Mar 7, 2007 | 10:43 AM
Casethecorvetteman
I downloaded it and got it up and running, here is what it looks like:
Its very much the same as the TunerCat for older models.
Old Mar 7, 2007 | 01:32 PM
kwik_ta's Avatar
kwik_ta
AWESOME!!!! Thanks Case
I looked into LT1 Edit a while back but was also told I needed some kind of data capture software to help with the fuel mapping and spark curves and stuff... overall it was a bit mroe than I wanted to spend at the time. I wanted to finish my mods first then worry about the reprogramming... well now I don't have much choice
Old Mar 7, 2007 | 01:34 PM
Casethecorvetteman
No worries mate, glad to help Ive never used LT1 Edit so i dont know how the 2 compare, but from what i read in one of the links i posted above and my personal experience with TunerCat, it does everything youll need to do.
To LTx Computers - do they interchange
