Pre-cats
Old Mar 24, 2007 | 12:19 PM
gmanvette's Avatar
gmanvette
Default Pre-cats
Did 1988 convertables come with pre-cats from the factory?
Old Mar 24, 2007 | 12:24 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
I'm 99% sure they did.
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Yes, I believe every L98 car after '85 did.
Old Mar 24, 2007 | 12:27 PM
gmanvette's Avatar
gmanvette
Mine only has the main cat. What will this do to emissions levels?
Old Mar 24, 2007 | 12:36 PM
zr1fred's Avatar
zr1fred
Assuming nothing else is wrong and the rear cat is good, it should pass without them. The pre cats are just there for cold starts.
Old Mar 24, 2007 | 01:09 PM
vader86's Avatar
vader86
All from 86-91 have them stock.
If you dont then someone replaced it, but the precats dont affect emissions that much (once the engine is hot) if the main cat is good. Once the engine is hot then you'll pass a sniffer.
Old Mar 24, 2007 | 02:57 PM
1988redvette's Avatar
1988redvette
I have a 1988 convertible with 4+3, and it came factory with precats. The original front y looked to be 2.25 inches in diameter, and I just upgraded to a new 2.5 inch y with precats and magnaflow converter. It definately feels more powerful.
To Pre-cats
