Quick emblem question
Old Mar 26, 2007 | 06:01 PM
85C4Man's Avatar
85C4Man
Default Quick emblem question
Hi there. I just recieved my new emblems today and the hood emblem has no nuts or even THREADS to put nuts on. It says it is genuine gm parts, but from everything i read it sounds that they SHOULD atleast be threaded. Anyways whats my best bet to get these babies on the car? thanks!
Old Mar 26, 2007 | 06:27 PM
The Green Hornet's Avatar
The Green Hornet
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
Get an assorted package of speed nuts at auto zone or someplace, the'll cut threads on the studs
Old Mar 26, 2007 | 06:40 PM
85C4Man's Avatar
85C4Man
Great thanks.. Is it best to cut the threads with it off or just do it on the car?
Old Mar 26, 2007 | 06:47 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Do it on the car that way it will stay tight. Your original should have the speednuts on it, when you remove the original one just put a dab of silicone in the socket so you don't lose the nut or you will have to go fishing with a magnet. You can reuse the original speednuts with no problem. If you don't have the originals then a trip to the hardware store is needed.
Old Mar 26, 2007 | 08:50 PM
CoolVette86's Avatar
CoolVette86
From: Partying with the Cowboys cheerleaders in Mt. Olive, New Jersey
Call me crazy, but from the wise words of a long time forum brother, I used rubber vacuum/windshield washer hose. That's right, I cut two pieces off of a hose, then reached in and put them on. That sucker is tight! You will not be able to pull them off easily, unless tools are used. Give it a shot, you can always try the speednuts later. Good luck.
Old Mar 26, 2007 | 09:21 PM
pipe's Avatar
pipe
Another good tip don't peel the tape off the back of the emblem and stick it on the hood that way if you want to take it off easy you can to clean or wax under/around it then put it back on. Pipe
Old Mar 26, 2007 | 09:36 PM
rodder robert's Avatar
rodder robert
works great did it on mine that way!
To Quick emblem question
