LT1 Throttle Cable
Old May 7, 2007 | 10:55 AM
  #41
rickneworleansla's Avatar
rickneworleansla
Hey Doug/Case which cable in the below pic is for the cruise control or am I looking at the wrong thing? I had the ASR cover off last weekend tightening my plugs but I didn't see a way to remove these cables. I still havn't been able to resolve the cable issue. At the track yesterday on my first run it was way low and again no nitrous. As I was sitting in the lanes waiting I used my method from before. I pushed the button in, pulled the cable all the way to the windshield, then got in and floored it to fix the high idle. On that run I gained 12mph on the top end and ran a second faster. Obviously the nitrous worked well and was reading WOT. I got back in line for the next run and ran again. This time low throttle again and the performance was back to where it was. Also nitrous not working again. Why does it keep going back to less than full throttle? What am I doing wrong here?
Old May 7, 2007 | 11:52 AM
  #42
94ZR1's Avatar
94ZR1
St. Jude Donor '06
Its just to the right of that pic on the cable going from the ASR to the throttle body
BTW the ZR1 has this adjustment also
Old May 7, 2007 | 01:07 PM
  #43
wmupaprmkr's Avatar
wmupaprmkr
Cool Hand Luke of W MI
Roughly how far do you depress the locking tab button?
I tried the other day to do this and I cannot get the button to push in.
Thanks!
Old May 8, 2007 | 09:40 PM
  #44
corvette49rdave's Avatar
corvette49rdave
Originally Posted by pr1mu5
"Hi All,
I read some other thread on here about how to adjust your throttle cable.
If you have no idea what this is, GO DO IT NOW!!! NOW!!!..........driving around town, I could definitely feel the extra throttle.
So, if you want one of the fastest, easiest, and cheapest mods to your car for performance gain, go check your throttle!!
John
I just performed this adjustment on my '92, and OMG WHAT A DIFFERENCE!!! Pictured below is the throttle cable/ASR assembly on my Vette....
With the car off, I simply depressed the 'THROTTLE CABLE ADJUSTMENT BUTTON' on the 'THROTTLE CABLE (ASR MODULE TO BUTTERFLY)', and slid the housing (indicated by the two asterisks) TOWARD the ASR module until it stopped moving (noting the tension increase on the 'THROTTLE CABLE AT BUTTERFLY'). After doing this, I depressed the gas pedal (with the car off), and noted that the throttle now opened up all the way, and hit the stop (heard the previously mentioned "Clink" as it hit the stop). Great! Now I shut the hood, and took her for a test drive....WOW! Power which I never knew was there was suddenly unleashed....Great thread, everyone with an LT1 should check their throttle, and perform adjustment as necessary!
Old May 9, 2007 | 08:17 AM
  #45
pr1mu5's Avatar
pr1mu5
Cool, huh?
Old May 18, 2007 | 08:28 PM
  #46
rickneworleansla
I just finished adjusting it again. This time I removed the clip on the ASR servo box. There was about a quarter inch to half inch slack here at the end of the cable. I tried moving it to a further hole but it would not reach. I had to push the button in on the throttle cable and move it just a bit. It reached the next hole at the servo box and took the slack out. The FSM says not to move the throttle cable because it may not go back to the correct idle, but being frustrated I tried it. It seems to have fixed the not reaching WOT issue but I don't know if it will stay fixed. It is idling just a bit higher. It now idles around 800 rmp but if I push in on the throttle lever it quiets down to about 700. I believe stock idel is around 600rpm. Is there any thing I should do to re-adjust the idle now? I think the WOT will keep working but I don't know if the higher idle will be a problem. Suggestions?
Old May 19, 2007 | 11:27 AM
  #47
BlackC6LS3's Avatar
BlackC6LS3
Okay guys, here is the be all end all answer for 93 models from the FSM. It probably works for other years, but I do not guarantee anything. It would be helpful if someone could make a sticky out of these images for future reference. All of the previous posts reflect a variation to this procedure but each misses the first part which seems like an important point.
Enjoy,
Dave
If anyone wants higher resolution pictures, shoot me a PM with your email address and I will be happy to send them to you.
Old May 19, 2007 | 11:20 PM
  #48
ELVIS' C4's Avatar
ELVIS' C4
From: Sugar Land, TX (suburban Houston area) U.S.A.
St. Jude Donor '09, '13
Thanks for posting the pics of the 92...I'll do mine tomorrow!!!
Old May 23, 2007 | 11:46 PM
  #49
Cmanhome's Avatar
Cmanhome
I had checked the throttle cable on my 95 last week and found out that is was only opening about 80% of the way open. Pushed on thebutton on the assy where all the cables come into and the slack in the cable disappeared and violla I had wide open throttle again. What a difference in performance.
Cmanhome
Old May 24, 2007 | 01:22 AM
  #50
rickneworleansla
Cmanhome
Check it again in a week or so. I would go to about 70 and floor it. I could tell something was wrong because it was not down shifting like it was supposed to at WOT with an automatic. It would only slowly increase. Mine kept going back to about 89% or so. I had slack in the cable by the servo assemply. The pin needed to be moved to take the slack out. I now have 100% for the first time in over a year. Wow what a difference. Everyone should check for this. Time to get back to the track for some new times.
Old Mar 27, 2008 | 07:41 PM
  #51
Road Agent's Avatar
Road Agent
If it's a 92 don't forget the drill bit.
Old Mar 27, 2008 | 08:08 PM
  #52
rickneworleansla
Drill bit?
Update: My cable continues to lose adjustment. Sometimes it takes a week, sometimes it's longer. I think I need to replace the throttle cables. Unless someone has another solution.
Old Mar 27, 2008 | 10:06 PM
  #53
Raydarlove's Avatar
Raydarlove
Drill bit?
Drill bit?
Old Mar 28, 2008 | 04:13 PM
  #54
qwiketz's Avatar
qwiketz
My throttle position cable is out of wack. I also noticed that the shifting is taking way to long to do at part throttle. Are the two interrelated? Will fixing my throttle body not going 100% affect my trans? My car is a 92. Or do I need to adjust the tv cable per the photos that blackrose posted?
Old Mar 29, 2008 | 01:23 PM
  #55
qwiketz's Avatar
qwiketz
adjusted both the trans and throttle cable per the thread. It works much better now. Thanks guys!
Also, my throttle cable adjusted to the left of the button on my 92. I mean to the asr box side of the button you push.
Old Mar 30, 2008 | 03:07 PM
  #56
Randy93's Avatar
Randy93
St. Jude Donor '06
Okay, think I know the answer BUT. I adjusted mine all the out on my 93 and I still am at only 90% with the pedal down.
a) does this mean I need new cables?
b) Do I have to adjust the cable from the pedal to the ASR?
Old Mar 30, 2008 | 08:53 PM
  #57
NEVRL8T's Avatar
NEVRL8T
Cool thread
To LT1 Throttle Cable
Old Mar 31, 2008 | 12:43 AM
  #58
Eddie & the Cruisers's Avatar
I have a '94 and would like to know where the 'early-late' begins and ends. My VIN# ends with 1000338 and was built in August, 1993 - I'm assuming it is an early version.
My '94 FSM does show early-late pictures of the T/B accelerator cable adjustment as Casethecorvetteman stated, and the proceedure is different on early-late. There is no trans. cable adjustment. Is '94 when the A4 electronic trans. came in the picture?
I can't check my car because it is in the shop getting a HP lift but is supposed to be ready tomorow (Monday). Can't wait!
When ordering the MSD ProBillet distributor, they showed early-late '94's, but all '92-'94's are the same for the opti and changed in '95. So the early-late opti thing IS a screw-up.
Oh, Case, do you have to read your FSM looking in a mirror since it is right-hand drive?
Old Mar 31, 2008 | 12:58 AM
  #59
The '93 must be the same as the '94 since someone mentioned the 1/8" drill bit used in the adjustment on the '92.
So, question b) is automatically adjusted by pushing the accelerator all the way down to WOT after you adjust the T/B accelerator cable. It ratchets for correct adjustment, but don't remove the 1/8" drill bit until after the accelerator WOT adjustment is made.
Old Mar 31, 2008 | 09:46 AM
  #60
NEVRL8T's Avatar
NEVRL8T
Where the hell do you use the drill bit on a 92?
