Starting My Winter Projects
Old Apr 14, 2007 | 09:52 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Starting My Winter Projects
Dooooh !! Yeah, it's spring, but I have been busy and golf season is in full swing.
I did knock off the heater core a while back, but that wasn't a planned project. I won't get all my list knocked off, but I will start the following list after golf tomorrow.
Tighten every fastener I can find in the dash area
dye carpets
install key-less entry
install dvd in dash stereo
install inside window seals
install upper door trim on pass side
install door weatherstripping
burn chip for motor
install new air dam
tint windows
install new floor mats
and what ever needs attention while in progress.
I hope to be on the road within 2 weeks, just in time to terrorize the newly paved road to the golf course.
Old Apr 14, 2007 | 09:54 PM
PUNISHER VETTE's Avatar
PUNISHER VETTE
might as well come do mine too.
I'll PM you my address.
Old Apr 14, 2007 | 10:03 PM
JackDidley's Avatar
JackDidley
dye carpets
install new air dam
burn chip for motor
Thats quite a list, but the floor mats only qualify as a project if you have a C5.
Old Apr 14, 2007 | 10:18 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
You really said that, didn't you?
Old Apr 14, 2007 | 10:22 PM
JackDidley's Avatar
JackDidley
Devil made me say that.
Old Apr 14, 2007 | 10:34 PM
AGENT 86's Avatar
AGENT 86
I had to throw that one in there since it's such a great topic.
Old Apr 14, 2007 | 10:48 PM
Corvette Chris's Avatar
Corvette Chris
I'm interested in hearing how dying the carpet goes for you. That's something I've been considering doing. Pics would be nice.
Old Apr 14, 2007 | 11:43 PM
AGENT 86's Avatar
AGENT 86
Pics are a must for any thread
Old Apr 15, 2007 | 01:14 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Bud, you seem to be off on the seasons... Its spring.....
Old Apr 15, 2007 | 03:03 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Didn't know there were inner top door seals available, aren't they part of the door panel?
What keyless system are you using? You can probably do the whole thing just at the existing module, it should have all the wires you need there. I remember tapping a second harness, it was in that footwell too, maybe for the hatch pop.
Old Apr 15, 2007 | 08:20 AM
AGENT 86's Avatar
AGENT 86
The inner window seals are stapled to the upper trim, but are replaceable.
I'm using the Bulldog 1702 keyless entry kit. Bulldog supplies some good info on what wires need to be tapped and where they are located. That and the FSM, should make the install fairly easy.
Old Apr 15, 2007 | 08:33 AM
JackDidley's Avatar
JackDidley
86, I did not have a way to staple those inner door seals. Small pop rivets worked well. That is a small job that really improves the interior. Not too expensive either.
Old Apr 15, 2007 | 10:13 AM
AGENT 86's Avatar
AGENT 86
Thanks I've read that some have re-used the original staples and some have used rivets. Once I see what going on, I'll choose what option to go with.
1 hour till tee time, time for some breakfast
Old Apr 15, 2007 | 10:55 AM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
It's a cliche, but its also true - and I have a C5 ...
Old Apr 15, 2007 | 11:01 AM
JrsTurn's Avatar
JrsTurn
Been gone for awhile so this may be old news. Did you get anywhere with the ram cnc project? It's not on the list...
Old Apr 15, 2007 | 03:31 PM
AGENT 86's Avatar
AGENT 86
It's on hold since he broke more bits trying to do just the grooves. He was trying with the wrong bits, so he's looking into getting the correct bits and trying again.
Old Apr 15, 2007 | 04:23 PM
midlifecrisis91's Avatar
midlifecrisis91
St. Jude Donor '03-'05-'06
Don't let them call you Mr. Divot
Old Apr 15, 2007 | 08:01 PM
AGENT 86's Avatar
AGENT 86
They could
To Starting My Winter Projects
