Electrical Problems, HELP
Old Apr 15, 2007 | 03:29 PM
NY93ruby's Avatar
NY93ruby
1st Gear
Default Electrical Problems, HELP
Hello,
I have a 93 Ruby automatic and recently the radio/casette player has stopped working. Now the car will not start after sitting for a couple days!!
It will after a charge but then the next day dead again. The battery is only a year old, and the mileage is at 40,000. Is it the dreaded optispark problem? I am not mechanically inclined so it will have to go to the dealer. Any suggestions, maybe just a short somewhere??
Thanks for any advice.
Marcia
Old Apr 15, 2007 | 03:45 PM
clf93lt1's Avatar
clf93lt1
not opti, check the battery cables.
Old Apr 15, 2007 | 03:53 PM
aminnich's Avatar
aminnich
There is a drain on the battery when parked. Meaning something is 'on'. Most circuits are fuse protected against a short circuit, so that is unlikely, still possible, but unlikely. The next step would be a visual look for something left on (interior lights, under hood lamps, blower motor, etc, etc.) followed by an inidividual circuit draw test. A bad, or shorted, alternator can also drain a battery when parked and any auto parts store can bench test an alternator for you. The radio/cd player maybe just a fuse, or it might be related, you would have to check it out to be sure.
Old Apr 15, 2007 | 06:18 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Search function on this topic, there's tips, tricks and info on how to find and diag power drains...
To Electrical Problems, HELP
