climate control problem 1988
Old Apr 21, 2007 | 08:06 PM
Ltt's Avatar
Ltt
Navigator
Default climate control problem 1988
After removing the climate control unit and cleaning all electronic connnections, I still have a problem of getting hot air from floor vents (only) with the climate control in the off position. With the out side temp of 70 degrees and setting the climate control to 60, the air cond kicks on but throws hot air(I know the a/c may need charging) but the air is very hot as if the heater is on, not the a/c. Could I have a vent door sticking open? If how and where under the dash? Could the front or rear vaccum air diverters be the problem? Any help will be appreciated.
Old Apr 22, 2007 | 09:50 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/dankai/AC%20Electronic.pdf
