drip drip drip.....
Old Apr 21, 2007 | 10:58 PM
jbodner246's Avatar
jbodner246
Default drip drip drip.....
89 c4... any common leaks on these things? i think its the oil pan but i cant tell
Old Apr 21, 2007 | 11:23 PM
bogus's Avatar
bogus
too funny. Just way too funny.
Sorry...
Do you want it in alphabetical or order of importance? Lets do importance.
1. Rear Main Seal
2. Oil Temp Switch
3. Oil Pressure sensor and fuel pump oil pressure switch
4. Intake
5. Front crank seal
6. Timing cover
7. Oil filter housing
8. Oil pan
I think that's all of'm.
Old Apr 22, 2007 | 12:01 AM
msslp04's Avatar
msslp04
St. Jude Donor '11,'14
I had a small oil drip from my 89. I crawled underneath and found 3 bolts missing from the oil pan. I replaced and tightened all bolts and now no more leak.
Kevin
Old Apr 22, 2007 | 12:12 AM
williammackean's Avatar
williammackean
St. Jude Donor '07
Sorry...
1. Rear Main Seal
2. Oil Temp Switch
4. Intake
5. Front crank seal
6. Timing cover
8. Oil pan
Valve Cover Gaskets.
Head Gaskets
Old Apr 22, 2007 | 07:12 AM
Chris44m's Avatar
Chris44m
2021 C4 of the Year - Modified Finalist
Default yea
I was looking at the oil spots on the garage floor were my 1989 roadster rests, and thought...hmmm, i'll put some cardboard under the front, and try and figure were its comming from...next day..pull out the card board...
Well...lemme sing you a song
Old Mcvette man had a vert e..i...e...i..o with a drip drip here and a drip drip there...everwere a drip drip!
The cardboard looked like a modern art masterpiece!
i'll button her up someday...but not this day!
Happy Trails
Old Apr 22, 2007 | 08:51 AM
bizaro's Avatar
bizaro
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
[QUOTE=bogus;1559921100
1. Rear Main Seal
2. Oil Temp Switch
4. Intake
5. Front crank seal
6. Timing cover
8. Oil pan
I think that's all of'm.[/QUOTE]
Has the potential to be a good thread. Just need to attach the step by step fixes.
Old Apr 22, 2007 | 09:04 PM
Tommy T-Bone's Avatar
Tommy T-Bone
St. Jude Donor '06-'07-'10-'11-'12-'13-'14
You are not alone. Parked on my mothers gray painted driveway. When I backed out I noticed...........oil drips........
This list will come in handy for me right now.
Old Apr 22, 2007 | 10:09 PM
bogus's Avatar
bogus
Head Gaskets
valve covers, yes, head gaskets, no.
There is no oil pressure at the head gasket in the SBC, it's all where it falls down. I would be SHOCKED to see an oil leak there.
Old Apr 22, 2007 | 10:20 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Sorry...
1. Rear Main Seal
2. Oil Temp Switch
4. Intake
5. Front crank seal
6. Timing cover
8. Oil pan
And that's just the oil leaks. Andy didn't even mention the leaks when it rains.
Old Apr 26, 2007 | 01:00 AM
jbodner246's Avatar
jbodner246
i actually ( with the aid of much black silicone ) fixed the water leaks. Valve covers i did already so its not those. ive narrowed it down to rear main seal and/or oil pan
Old Apr 26, 2007 | 01:06 AM
JD'S WHITE 93's Avatar
JD'S WHITE 93
http://forums.corvetteforum.com/show....php?t=1683502
Go buy some u.v. dye and you'll find your leak/s
Old Apr 26, 2007 | 01:11 AM
jbodner246's Avatar
jbodner246
yeah dont have access to a lift right now to really get under there with a black light but im gonna do that soon
Old Apr 26, 2007 | 01:16 AM
JD'S WHITE 93
Jackstands will work, I got my car up high enough to pull the rear end and the trans last winter.
Old Apr 26, 2007 | 06:09 AM
moore299's Avatar
moore299
Happy Trails
Hey, that could be some cool art work for the wall. The day when you can look back and say....Remember those days......
Old Apr 27, 2007 | 02:18 PM
FireLt90's Avatar
FireLt90
Cruising
Hi all. First post here. I'll update my profile and add some pics soon but I needed to add to this thread.
Just got a new used 1994 Polo green. When I parked I smelled oil burning. Took it in for a nice Mobil 1 oil change and he said the "speedometer adapter" is leaking onto the exhaust. Said it's not a big deal and if I ever change the exhaust, which I plan to do, that would be a good time to seal it up. Does this make sense to anyone?
Old Apr 27, 2007 | 02:27 PM
torchred89's Avatar
torchred89
Many years ago I was a paratrooper and I was jumpmaster on a jump when I hung out the door of the plane to make sure no other aircraft around, I noticed oil running down the side of the plane ( a old C123) I told the air Force loadmaster what I saw, He said thats good when it stops we got a problem.
Old Apr 27, 2007 | 02:57 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Mine does the same thing. I'll store it for the winter, the seals dry out and it'll leak at the speedo adapter (and other common areas) for a couple of days until they're moistened back up again from oil circulation.
Old Apr 27, 2007 | 04:16 PM
FireLt90's Avatar
FireLt90
Cruising
Ok great. I'll just keep an eye on it then.
Old Apr 27, 2007 | 05:51 PM
raccer's Avatar
raccer
Happy Trails
Chris!?
You collect this rare art too!?!?!?
we should collaborate and discuss opening a gallery somewhere!
This almost motivates me to go clean the drip pan off and then after my car does its nasty all over the drip pan I can post it and you can tell me if my art is better or worse than yours.........
-Merrick
To drip drip drip.....
