Skipping wipers
Old Apr 26, 2007 | 08:15 PM
Allieboy's Avatar
Allieboy
Default Skipping wipers
usually wipers skip when dry but mine skip when wet. would replacing em fix the problem i rem reading somethin but i cant find it agn
thx in advance
Old Apr 26, 2007 | 08:37 PM
Joe C's Avatar
Joe C
http://forums.corvetteforum.com/show...ighlight=wiper
Old Apr 26, 2007 | 08:54 PM
78pacer's Avatar
78pacer
I drove from Carlisle to Ct 2 summers ago with chattering, skipping blades. It was the same deal. They were fine dry, but once wet.........fughettaboutit! I took a straight blade razor to the windshield to 'shave' off any debris. I cleaned it with alcohol, ammonia, citrus and nothing helped. I replace the blades with Anco's, still no luck. If you find a cure, pass it along.
Mike
Old Apr 26, 2007 | 11:17 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Try flipping the blades over.
Old Apr 26, 2007 | 11:24 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Mine only skip in one direction, so 65Z01 might be onto something.
Also, it seems like slop in the linkage isn't helping any.
Old Apr 26, 2007 | 11:30 PM
ynk1121's Avatar
ynk1121
new blades didn't help me so i figured the spring in the arms were starting to stretch. after comparing the old and new i noticed my wiper arms were bent. haven't had a problem since i got new ones.
Old Apr 27, 2007 | 12:57 AM
or92vette's Avatar
or92vette
Clay the windshield. That stopped the chatter on both my Honda and the Corvette.
Old Apr 28, 2007 | 07:27 AM
Allieboy's Avatar
Allieboy
sorry but Clay the windshield?
Old Apr 28, 2007 | 09:37 AM
Riks40th's Avatar
Riks40th
From: St. Louis, Mo......... 1993 Torch Red w/White Interior...2006-07 Bloomington Gold 2005-ZR1/C4 Gathering, 2001-2012 Funfest
That will pull all the contaminents off and make it really slick. If they still skip them you probably have bent arms.
Rik
Old Apr 28, 2007 | 10:15 AM
2HIP4U's Avatar
2HIP4U
To permanently solve the problem you have to bend the wiper arm to a point where the wiper blade is perpendicular to the windshield.
When the wipers shut down, there is a twist put on the wiper arms. This constant pressure eventually bends the arms enough that the blades are angled up against the windshield, causing the chatter.
Take two adjustable wrenches and gently twist the wiper arm until the blades are exactly perpendicular to the glass. This will stop any chatter.
Old Apr 28, 2007 | 01:48 PM
CentralCoaster
Clay bar. Your local auto parts store should have it. They usually come in a box along with a bottle of spray.
To Skipping wipers
