93s
I have always loved the polo green.
I have never heard anyone; ever, say that they liked their early C4 better than their late C4.
Sometimes it is better to stop throwing money in a car and get the one you want.
I can understand not wanting to spend the money and time for the transmission swap.
Just in case you are wondering, I have a Ruby Car. No offense meant!
There is a fairly good reason Corvette designed it into the car in '92 C4, C5 and C6.
For instance, in case you use the car in the winter/colder months (doesn't have to be winter to get down below 40 or so), depending again (mostly) on tires, and road conditions, your car good easily lose traction very quickly at many different speeds. While you can overpower ASR, it may be the only thing that keeps you from a bad situation.
Try it out in an empty parking lot with not too many lite poles around. It's also a good way to get a feel for the car. If after that you feel confident running around without asr, have at it.
Just my suggestions. Good luck with the car.
[gosh, i sound like a nattering nanny.....]
Its a 93 Pologreen and i just realized today that its a 40th Annv "im so sike to find that out
"Can someone tell me alittle about the ASR i noticed it had that also wich i only see there was alittle over 800 made production wise.
Let me know what the forum thinks
This ting is sooo much better than my 86
Repzard
Looks like a real Beauty.The ASR (Traction control) is standard for all '93's. You're probably refering to the Adjustable Suspension Package of which there were only 824 in '93.
