93s
Old Apr 28, 2007 | 08:23 PM
Repzard's Avatar
Repzard
Default 93s
Im going to look at a 93 tomorrow how are they as far as problems go ?
What should i look for ?
I know its a LT1 with 300hp , a Auto trans and Dark Green(pologreen) in color
I would like some opinions from the forum
I have a 86 as we speak and it hasnt been to good so far to me.
I think the 4+3 let go and not sure if i want to spend the money to do a ZF6 or Keisler swap when i can just buy another Vette with some of that money.
Old Apr 28, 2007 | 09:08 PM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
I picked up my '93 40th anniversary in Dec. 06. Once you drive it, you'll be impressed. The difference between it and the early C4's is like night and day. Less squeaks and rattles and the LT1 flies! Drive the car and decide. Enjoy!
Old Apr 28, 2007 | 09:37 PM
redwing76's Avatar
redwing76
That was pretty much my experience.....
Old Apr 28, 2007 | 09:43 PM
zapitbullseye's Avatar
zapitbullseye
And when you get it, be sure to show it off to your friend. Maybe he'll ditch the elcamino and get a Corvette too!! Then ya'll could cruise in true LT1 style!
Old Apr 28, 2007 | 10:10 PM
Repzard's Avatar
Repzard
I cant wait to take it for a test drive
I think its going to be a sleepless night
Because im so excited that it could be mine and i can say goodbye to the 86 which i havent had much luck with, Just wish it didnt have the 4+3 or i would be keeping the 86 .
Thanks Forum members
I will keep you all posted how it goes
So wish me luck
Repzard
Old Apr 28, 2007 | 10:25 PM
VetteUSA's Avatar
VetteUSA
St. Jude Donor '07
There's nothing out of the ordinary as far as problems go...
If your water pump goes, then there's a 99% chance it will kill your optispark. No opti = dead in the water. The other thing you may have to watch out for is the dreaded VATS problem. Being stranded by VATS is a royal PITA. 1993 was also the first year for the PKE. The PKE can be an annoyance at times, but you can leave the fob at home if you don't want to deal with it.
Old Apr 28, 2007 | 10:39 PM
Repzard's Avatar
Repzard
I believe my 86 has VAT(chip in the key) so i know all about that issue.
What is the PKE not really sure what that is if you can fill me in.
Old Apr 28, 2007 | 10:46 PM
VetteUSA's Avatar
VetteUSA
St. Jude Donor '07
Passive Keyless Entry.
The key fob has a proximity transmitter, so that when you walk up to your vette (3 to 5 feet from it) , the alarm will automatically disarm itself and the door(s) will automatically unlock. It is particularly annoying when, for instance, you are washing your car and the alarm keeps arming/disarming and the doors keep unlocking and locking. There is a receiver antenna in the driver's side door and the rear hatch area. You can, though, turn off the PKE. You can still arm your alarm manually with the PKE off.
Old Apr 28, 2007 | 10:56 PM
Repzard's Avatar
Repzard
Thanks VetteUSA good thing to know
Old Apr 28, 2007 | 11:05 PM
VetteUSA's Avatar
VetteUSA
St. Jude Donor '07
Also, just an FYI, The fobs for the coupe and the vert are different. The fob for the coupe has two buttons, one to unlock the doors and the other one to open up the hatch. The vert fob will only have a single button to unlock the doors. P.S. I think the vert has the PKE antenna in both doors, whereas the coupe is the one with an antenna in the driver's door and rear bumper/hatch area.
Old Apr 29, 2007 | 05:43 AM
JD'S WHITE 93's Avatar
JD'S WHITE 93
I had a 85 and an 89 and once you drive the 93 even with the sissy 2.59 rear gears if so equipped you'll be sold.
Old Apr 29, 2007 | 06:01 AM
slicked25's Avatar
slicked25
WOT is very addicting. You just can't get enough of it.
Old Apr 29, 2007 | 06:39 AM
timmy 93's Avatar
timmy 93
check the options on the car.FX3 can be vary expensive to repair.If it has sport seats make sure all pumps and motors work lumbar bladers inflate seat goes up down back and forth.You should see a service ride control light if FX3 is not working.check codes if possible. As stated the LT1 is worth the ride good luck Tim
Old Apr 29, 2007 | 07:28 AM
78pacer's Avatar
78pacer
You really want to go from a stick to an automatic tranny??
Mike
Old Apr 29, 2007 | 07:34 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Well, if you've had expensive 4+3 problems, I guess I can understand the move to auto trans. I owned 6spd '93 from new. I think it was a great car, and the color is superb, Polo Green.
As mentioned, probably only the opti and the auto trans are the issues to be concerned with. It IS a 15 year old car, so, of course, that's to be taken into consideration. Before you make the decision, make sure it goes up on a lift and gets a thorough going over by you or your tech/mech.
Finally, a carfax would put some other issues potentially to rest. Tell us all about it after the ride.
BTW, I had the keyless entry, and it was ok, better in fact I think than the '96 keyless entry (which I left in the kitchen drawer ).
Old Apr 29, 2007 | 07:38 AM
sonomacrew01's Avatar
sonomacrew01
check the opti and waterpump... OIl leaking at the rear and front of the intake is a common problem. These problems are weekend fixes though. Enjoy the potential 93
Old Apr 30, 2007 | 03:18 PM
Repzard's Avatar
Repzard
Well i took the vette out for a test spin.
What a bute..She is.
The car is Polo green with tan (saddle i want to say it is) insides
The vette is in very good shape for a 93 and has some sack.
Cant believe what ive been missing all this time and the LT1 what a differants to my L98.
so it looks like i will be getting this Vette and saying goodbye to my 86 Vette.
To go from a stick to a auto doesnt really bother me much.
To be honest its a little more relaxing not having to shift in traffic.
When i do get her i will post some pictures.
Hope to have her by next week the lastest.
Till then thanks forum for all your info.
To 93s
Old May 2, 2007 | 08:39 PM
Repzard's Avatar
Repzard
Default Update for the 93
Well here she is my new Vette
Its a 93 Pologreen and i just realized today that its a 40th Annv "im so sike to find that out "
Can someone tell me alittle about the ASR i noticed it had that also wich i only see there was alittle over 800 made production wise.
Let me know what the forum thinks
This ting is sooo much better than my 86
Repzard
Old May 2, 2007 | 08:49 PM
Repzard's Avatar
Repzard
ok cool
I turned it off when i first noticed it so i did good
know it was some traction control type thing
Thank you
Old May 2, 2007 | 08:51 PM
VetteUSA's Avatar
VetteUSA
St. Jude Donor '07
ASR = Acceleration Slip Regulation = Traction Control
ASR began in '92, The ASR on/off button is located above your headlight switch. The ASR ECU monitors drive wheel speeds, vehicle reference speed, speed diff of non-driven wheels, front-to-rear wheel speeds, vehicle accleration and throttle position.
Basically it annoys the hell out of everyone, so the easiest thing is to just always turn it off when you start up the car.
