Need Help- 1989 Remove Hatchback Shade
Old May 1, 2007 | 01:28 AM
guy ferrante's Avatar
guy ferrante
4th Gear
Default Need Help- 1989 Remove Hatchback Shade
I am trying to remove the shade that covers the storage area and cannot figure it out. It has the mechanics of a shade you would find in a home-it moves from side to side but will not release.
The reason for removing it is to get to the solenoid that controls the hatchback. Any Ideas?
Old May 1, 2007 | 01:35 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Use the search function and include archive posts in your selection, this has been covered on the forum, but sorry can't point you directly to it...I've never removed mine, but there is a release on one of the sides by the rear wheel well area...
Old May 1, 2007 | 02:52 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The privacy shade is spring loaded, like a pull-down window shade.
Press in on one end till it slides over enough to release that end. You may need to mess around with it if it hasn't rolled up evenly.
Old May 1, 2007 | 05:53 AM
Joe C's Avatar
Joe C
removing the shade was one of the bigger pain in the *****, i had with my 85. i found it best to remove it from the drivers side first - (it probably makes no difference). once you push toward the passengers side, a large flat bladed screwdriver as a prybar helps. note: i did have all my plastic trim out and was installing new carpet...
Old May 1, 2007 | 08:56 PM
guy ferrante
4th Gear
Default Shade
That is what I tried along with 2 other people- it still remains a mystery- I would think it operates the same as a shade in a home- As mentioned I am trying to replace the hachback solenoid and can't get to it- What a pain in the ...S.
thanks!:
Old May 2, 2007 | 09:36 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Think of it as a giant toilet paper holder.
Push towards the opposite side you are on, then on your side, insert a large screwdriver and push towards the opposite side and it slides right out. Takes about 5 seconds or so.
Old May 3, 2007 | 09:58 AM
guy ferrante
4th Gear
Default shade response
Thank You will try your suggestion-
Old Sep 18, 2007 | 07:08 PM
Red_Vette_93's Avatar
Red_Vette_93
I know this is an old post but I tried for a half hour today to get mine out.
Is the shade the same on a 93?
Old Sep 18, 2007 | 07:21 PM
65Z01's Avatar
65Z01
I think so as MrMojo was refering to a '93 (maybe a '95).
Old Sep 18, 2007 | 07:50 PM
jon0108's Avatar
jon0108
when changing the carpet on my 86 it seemed like it took forever to figure out how to remove the rear shade. Once i did it it was literally a 5 second job. Use a small pry bar on the drivers side end and just compress it. Dont worry you'll get it.
Old Sep 19, 2007 | 09:58 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
thanks!:
Do you need to remove the shade to remove solenoid. Haven't needed to mess with the solenoid yet, but when I have the rear trim off, that bugger is in my face.
To Need Help- 1989 Remove Hatchback Shade
