Window sweeps
Old May 9, 2007 | 02:05 AM
Allons's Avatar
Allons
2nd Gear
Default Window sweeps
Anyone know how to replace both inner and outer window sweeps for a 1991? Any on line sources or instructions?
Thank you for your time
Michael
Old May 9, 2007 | 03:05 AM
msslp04's Avatar
msslp04
St. Jude Donor '11,'14
Here's a link:
http://www.corvettemagazine.com/2001...ndow/win-1.asp
Found one more to help:
http://forums.corvetteforum.com/show....php?t=1600879
Kevin
Old May 9, 2007 | 01:28 PM
Allons's Avatar
Allons
2nd Gear
Thank you Kevin, that helps alot.
Michael
Originally Posted by msslp04
Old May 9, 2007 | 01:29 PM
thebeerman's Avatar
thebeerman
Not a real bad job as they go, but somewhat time consuming. You have to pull of all of the door panel stuff, the inner glued weather panel, drop the glass (make sure you mark the original locations before you drop the glass, drill out the old rivets, and rivet the new ones in. I would estimate the first time, 4-6 hrs from start to finish, both sides (total time).
Old May 9, 2007 | 01:33 PM
dfalliaux's Avatar
dfalliaux
St. Jude Donor '08-'09-'10-'11-'12-'13-'15
Excellent post, i was wondering the same...thanks for the info!
Old May 9, 2007 | 04:55 PM
msslp04's Avatar
msslp04
Michael
You are welcome! Take your time and make sure everything is in its proper place when you are done.
Kevin
To Window sweeps
