Busted Trunk Switch ~ Driver Door
Old May 13, 2007 | 01:38 AM
John Vuckovich's Avatar
John Vuckovich
Default Busted Trunk Switch ~ Driver Door
Hi,
The trunk switch on the inside of my drivers side door doesn't work, a fuse or ?
Any suggestions for the novice fixer?
Thx a million
Old May 13, 2007 | 01:44 AM
bogus's Avatar
bogus
does the passengers door work? what about the one under the console?
if they both work, replace the door switch. that would be a great start... the other option means removing the door panel and using a DVM to test the harness.
Old May 13, 2007 | 03:08 AM
Z51JEFF's Avatar
Z51JEFF
Originally Posted by John Vuckovich
Hi,
Yea,buy a Corvette that doesnt have a trunk.........
Old May 13, 2007 | 06:27 AM
VinceC4's Avatar
VinceC4
Hi,
Thx a million
You have a trunk?...Corvettes don't need no stinkin trunk
Old May 13, 2007 | 07:25 AM
78pacer's Avatar
78pacer
Try owning one without, you'll appreciate that stinkin' trunk.
Mike
Old May 13, 2007 | 11:00 AM
ACECO's Avatar
ACECO
St. Jude Donor '04 & '05
Mike
You get practically no space in a 75. The C4 seems cavernous compared to the original C3 style.
Old May 13, 2007 | 11:16 AM
John Vuckovich
I meant to say rear hatch or the space behind the seats. Had no idea I had to spell it out.
Old May 13, 2007 | 11:20 AM
msslp04's Avatar
msslp04
St. Jude Donor '11,'14
Somedays there seem to be more smart a$$ answers than real answers.
Kevin
Old May 13, 2007 | 12:45 PM
Z51JEFF's Avatar
Z51JEFF
[QUOTE=John Vuckovich;1560231745]I meant to say rear hatch or the space behind the seats. Had no idea I had to spell it out. [/QUOTE. Oh,that trunk switch,well as stated you have 3 switches,how many of them work,year of the car?
Old May 13, 2007 | 12:52 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Although no help to fix the actual problem, I just want to point out that not ALL year C4's have a switch on the passenger door.
I know my 1996 only has two (drivers door, and inside console). Two the OP, that is why it's always important to list what year car you are asking about. The C4 ran for 13 years, and there were many changes made to it through out that span
Old May 13, 2007 | 01:14 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
John,
What year is your C4? Early C4s had three switches (driver's side, passenger's side, console) while later ones (I think as of 1991, but I'm not sure) no longer had the passenger's side switch.
If the other switch(es) work than it's probably a problem with the actual switch or the associated wiring inside the door. Was something else fixed on the driver's side door recently?
Old May 13, 2007 | 05:14 PM
bogus's Avatar
bogus
gee... my post, the first reply, answers the question, yet everyone else had to get jerky over semantics.
Hi, John!
Old May 13, 2007 | 06:45 PM
Goldcylon's Avatar
Goldcylon
Kevin
Honest mistake geesh fiesty bunch today!
Goldcylon's Avatar
Goldcylon
Originally Posted by j3studio
John,
Yep 91s have all three
Old May 13, 2007 | 07:11 PM
FELNGR8's Avatar
FELNGR8
Hi,
Thx a million
On my car the switch that senses the door open is what was killing the hatch release function of the "hatch release switch" on the driver door. The door open sensor gets gummed up from road grime. The first time I hit it with CRC silicone spray and that freed it up, but now it needs a thorough flush with WD-40, or a switch replacement. My car is a 94.
Old May 14, 2007 | 11:17 AM
John Vuckovich
How do you remove the switch? (in the door, the side)
I tried with a small screwdriver but wouldn't come out, might break the plastic around it.
Old Dec 10, 2007 | 09:42 PM
gshrum1111's Avatar
gshrum1111
1st Gear
My hatch switch stopped working as well. After reviewing all the suggestions on this post, I came across this one. "The switch that senses the door open is what was killing the hatch release function of the "hatch release switch" on the driver door". Sure enough, a squirt or two of WD40 and I'm back in business. My wife thanks you for the info. She's tired of fishing her shopping bags out through the front.
To Busted Trunk Switch ~ Driver Door
Old Dec 10, 2007 | 10:30 PM
johnnymo63's Avatar
johnnymo63
2021 C4 of the Year - Modified Finalist
C4 of Year Finalist (appearance mods) 2019
If your having any problems with the dome light not coming on or the radio not going off when you open the door... it might be a door ajar switch.
(sounds like Jeff Foxworthy giving advise)
Old Dec 11, 2007 | 06:23 AM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
I guess I'll be buying some WD40 on the way home tonight. My dome light and hatch both stopped working at about the same time 2 weeks ago and I've been wondering how to fix them.
Excellent post.
Old Dec 11, 2007 | 06:32 PM
RICEKILA's Avatar
RICEKILA
From: Beautiful Down Town "SWINDLEHURST" Long Island NY
http://www.parts123.com/parts123/yb....Z5Z5Z50000050F
