Brake booster adjusting?
Old May 13, 2007 | 10:53 AM
Allentown Ernie's Avatar
Allentown Ernie
Default Brake booster adjusting?
I have just put new pads , and rotors on my 90 coupe. The brakes work just fine and stop very well. However the pedal is a little low,I would just like it a little higher. I read in other brake threads that you can adjust the rod on the brake booster. I have bled the lines. Does anybody have any experiance with this and can help me get the pedal a little higher? Allentown Ernie.
Old May 13, 2007 | 02:58 PM
Hotred94's Avatar
Hotred94
The rod adjustment inside the brake booster is a very sensitive adjust for the amount of vacuum boost, not for pedal height adjustment. You'll want to leave that one alone.
Old May 13, 2007 | 06:03 PM
robertt43's Avatar
robertt43
Very sensitive and does very little to give you more peddle.You can lock up the pads easily,scorching and glazing the rotors.
Old May 14, 2007 | 08:18 AM
Allentown Ernie
Thanks for the info, I will keep my hands off. Allentown Ernie.
To Brake booster adjusting?
