oil change/filter
Old May 19, 2007 | 11:01 AM
larryabbott's Avatar
larryabbott
Default oil change/filter
Hi, I am a 1st time owner of a Corvette, '92 vintage, so please don't flay me too badly. The current owner just changed the oil with Mobil 1, so probably less than 50 miles it. However, he used the dreaded Fram filter. Can I change the filter without losing all the oil? If I have to drain the oil first I'm assuming I can re-use the oil as long as I catch it in a clean container. Flay away. Thanks, Larry
Old May 19, 2007 | 11:04 AM
LS6 Motor's Avatar
LS6 Motor
Just remove the filter, and replace with the brand your comfortable with. It should be a quart or less, restart the car, shut off, check the level, and fill until reads full on the dipstick.
Old May 19, 2007 | 11:17 AM
Repzard's Avatar
Repzard
Old May 19, 2007 | 01:52 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Don't over fill, best methoud is to remove filter, then fill the filter with oil before installation.... install, run to opp temp and check, should be the same as when you started.
Old May 19, 2007 | 02:32 PM
c4cruiser's Avatar
c4cruiser
Remove the offending Fram filter and toss it. When you install the new filter, simply pour oil into the new filter before installing it. You should be able to get almost a half-quart into it by pouring slowly and then letting it sit for 10 seconds and then add more.
This way, you will have a nearly full filter when the motor starts.
You won't have to add much more oil at all after you install the filter and start the motor.
Old May 19, 2007 | 02:44 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Considering the prev owner has probably been using Fram filters for the past 50K+ miles, I'd just leave it on there until the next oil change. But the advice above is good also
Also, Corvette Kid was born yesterday.
Old May 19, 2007 | 02:48 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
with the above. I always prefill my filters. As stated, you'll get almost a half qt. in this one. Put the rest of that half a qt. in the engine and you'll be right, guaranteed. Then you'll have a half qt. left and only have to buy four more for the next oil change. Welcome to the brotherhood!
Old May 19, 2007 | 11:57 PM
jabez's Avatar
jabez
Old May 20, 2007 | 02:50 AM
corvette49rdave's Avatar
corvette49rdave
I would agree with all of the above, and recommend replacing Fram filter with K&N Filter HP-2001...Welcome to C4 land!
Old May 20, 2007 | 08:42 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
I've used Fram for many years, never had a problem.
Old May 20, 2007 | 09:05 AM
Pete K's Avatar
Pete K
Be patient. Trouble is pending
Old May 20, 2007 | 09:30 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
I agree Fram Filters are not the best but I think it's a waste of time to change it now. Do it on your next change and maybe a little earlier than you would normally.
Old May 20, 2007 | 09:33 AM
Iroc57's Avatar
Iroc57
Pardon my ignorance here but.......
What is so bad about a fram that would warrant immediate replacement?
I am new here and don't know the history on this topic.
Old May 20, 2007 | 10:11 AM
Muffin's Avatar
Muffin
There are studies(?) that show Fram has the lowest build quality when compared to the remainder of the filter population. I won't use a Fram filter but I have no personal or second hand knowledge of anyone having a major problem with one. I am confident Fram wouldn't sell a filter that is unsafe to use. Like I said, I won't buy one but in Larrys position I would't change just for the sake of changing.
Old May 20, 2007 | 10:16 AM
mikeb's Avatar
mikeb
2023 Corvette of the Year Finalist - Unmodified
2022 C3 of the Year Winner - Unmodified
I just wonder how Allied Signal can still be in business.
Old May 20, 2007 | 10:18 AM
Pete K's Avatar
Pete K
The power of advertising.
Old May 20, 2007 | 10:30 AM
BADDUCK's Avatar
BADDUCK
I doubt it, I use Pure 1 now, but unless you beat on your car really hard I think the new Fram filter is fine. They don't have the cardboard end cap in the new model.
To oil change/filter
Old May 20, 2007 | 10:36 AM
Pete K's Avatar
Pete K
I certainly wish you luck. If you were involved in the first hand problems that I was a part of, you opinion would be similar to mine.
I never have a negative opinion of any product that I have been succesful with, so I fully understand your view.
Old May 20, 2007 | 12:18 PM
Repzard's Avatar
Repzard
I only use what came on the car from day one and that the nice blue
AC DELCO
Cant go wrong IMO
but Fram I would never use
Old May 20, 2007 | 01:06 PM
N.C. Kid's Avatar
N.C. Kid
I use Fram "Sure Grip" and it seems fine to be. If it wasnt safe then it wouldnt be on the market.
