A/C = Service Engine Soon???
Old May 21, 2007 | 01:48 PM
Shimy86's Avatar
Shimy86
Default A/C = Service Engine Soon???
Hope someone can give me a hand with this. When ever I use the AC for more than an hour I get the Service engine light. If I only use it on short trips no trouble. This weekend went for a 300 mile ride and as usual, after about an hour of AC on comes the light. AC works great and car seems to run fine. Upon re-start no light. I dont have a way to get a code.
Anything I should be looking at ( other than a way to get codes )
Thanks!!
Old May 21, 2007 | 02:16 PM
mikey whipreck's Avatar
mikey whipreck
Assuming you have an 86 (by your SN), the a/c shouldn't throw a code by itself. What year do you have? I could throw out a guess, like the a/c is causing some noise that the ESC system is trying to compensate for, can't and throws a code, but that would be pulled outta my...
And FWIW, most parts stores (autozone) will check codes for you for free.
