A Stupid Question
Old May 28, 2007 | 12:39 AM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Default A Stupid Question
You know the silicone gel that comes with a new set of wires? If the gel gets onto the contact points of the cap and sparkplugs, could this cause a problem? I just installed new wires on my car, along w/ plugs, cap, rotor, coil, module, fuel filter, and the car breaks up over 3000 rpm. I can't seem to find the problem, and thought maybe this was it?
Anyway, no flames please.
Old May 28, 2007 | 12:53 AM
Pete K's Avatar
Pete K
Dielectric grease is very conductive. Should not be a problem. It is best used directly on the contacts. I smear a small amount on the rotor tip to prevent radio noise.
Old May 28, 2007 | 01:26 AM
RandyJ75's Avatar
RandyJ75
Thanks, Pete.
I found the problem, two injectors bad. Replacements on the way.
Old May 28, 2007 | 05:02 PM
robertt43's Avatar
robertt43
Default no
The grease is meant to stop the plug wire from fusing to the plug itself....I would look for a crossed plug wire,or a bad condenser,or a broken coil wire somewhere.... something is not connecting properly when you put more energy into it....Ask cfi/efi,he is usually very helpful with electrical hassels.....My 84 did that and it was the Rotor,which stopped when I switched to a copper tipped cap,and a quality rotor......Hope this helps,,,good luck
Old May 28, 2007 | 06:40 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Ground strap for coil ?? Rubber washer and carbon button for coil installed correctly ?? Correct firing order ??
Old May 28, 2007 | 08:19 PM
dknight129's Avatar
dknight129
St. Jude Donor '07
probably a loose connection somewhere.
good luck
Old Jun 14, 2007 | 12:56 PM
Rich Z's Avatar
Rich Z
I don't think so.
The DEFINITION of dielectric is:
  • A nonconductor of electricity, especially a substance with electrical conductivity of less than a millionth (10-6) of a siemens.
  • a nonconducting substance; insulator.
  • a substance in which an electric field can be maintained with a minimum loss of power.
  • Having little or no ability to conduct electricity, generally as a result of having no electrons that are free to move.
  • A material that conducts (see conduction) electricity poorly or not at all. If a voltage is applied to a dielectric, the atoms in the material arrange themselves in such a way as to oppose the flow of electric current. Glass, wood, and plastic are common dielectrics. (See insulator.)
  • a nonconductor of direct electric current
Old Jun 14, 2007 | 02:45 PM
All2kool's Avatar
All2kool
Pete K in '08!
I'd vote for him.
Old Jun 14, 2007 | 03:15 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Originally Posted by All2kool
Pete K in '08!I'd vote for him.
Except that he's in error on this one.
(see Rich Z's #7 post)
Larry
code5coupe
__________
Not easily impressed....
Old Jun 14, 2007 | 05:28 PM
cemnei's Avatar
cemnei
good luck
Just wanted to say, SWEET Avatar!!
Old Jun 14, 2007 | 05:40 PM
Pete K's Avatar
Pete K
Jeez, shoot me already.
I use it on everything. If I could, I would put it on my salad.
I offer free advice that is correct 99% of the time. You guys can argue it till page 6. I'm out of this one.
Old Jun 14, 2007 | 05:45 PM
VetteUSA's Avatar
VetteUSA
St. Jude Donor '07
There are no stupid questions, there are only stupid answers!
To A Stupid Question
