93 LT1 won't start
Old May 29, 2007 | 02:36 AM
josephbs's Avatar
josephbs
Default 93 LT1 won't start
Problem: I was driving down the highway, the engine died as if it were out of gas. Car would not restart.
Note: I had experienced some rough starting for the last month or so.
Tests: No spark when I checked one of the plug wires with timing light. All fuses check out ok. Check for codes with paperclip but nothing showed up.
Replaced: Ignition coil, ignition control module, fuel filter, fuel pump
Hypothesis: I'm thinking the problem is probably the optispark distributor.
Suggestions: ??????
Old May 29, 2007 | 07:34 AM
Aaron71771's Avatar
Aaron71771
Probably your optiospark, have you gone thru the diagnosis process in the service manual?
Old May 29, 2007 | 10:49 AM
SJW's Avatar
SJW
Diagnose the problem before you start throwing expensive parts at it.
See if there's spark coming out of the ignition coil. Take it from there.
Be well,
SJW
Old May 29, 2007 | 11:35 AM
daca's Avatar
daca
Check the service manual before you spend anymore $$$$$.
Old May 29, 2007 | 12:37 PM
rubyred93's Avatar
rubyred93
If it does indeed turn out to be your Opti, I HIGHLY suggest going with a DynaSpark unit vs. an OE unit.
My '93 went through 2 OE units (one at 25k and the other at 28k). Just recently replaced the 2nd OE unit with a DynaSpark. There really is no compaison between the two, the OE unit is just garbage.
Save yourself the aggravation of dealing with another GM Opti.
Old May 30, 2007 | 02:54 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Check the ignition wiring from from the coil to the Opti, too. It can get corroded.
Check your water pump weep hole. If it's leaking coolant, it's a sure bet it's doused and likely damaged your early, passively-vented Opti.
Remember, it only takes a thimbleful of coolant to kill the 1992-93 distributors.
Old Jun 2, 2007 | 10:32 PM
josephbs's Avatar
josephbs
Default Opti Choices
Went through all diagnostics in book. I'm pretty confident that it's the optispark at this point.
Trying to decide on which one to buy... Dynaspark seems ridiculously expensive at $599... MSD Pro-Billet LT1 looks nice but still almost twice the price of the one I can get from JEGS. Does anyone have any experience with the JEGS model? http://www.jegs.com/webapp/wcs/store...64013_-1_10679
Also, I think changing the waterpump or at least rebuilding it seems like a good idea when I put in the new distributor. Probably new wires and plugs too. Any thoughts or suggestions about this?
Note: The car has almost 170,000 miles on it.
How long do you guys think this will take me to remove and replace?
Old Jun 2, 2007 | 11:40 PM
corvette1989bham's Avatar
corvette1989bham
actually the OE optispark is fine, its the waterpump going bad thats the problem, if one were replaced in a few thousand miles of each other, I would suspect water pump leaking..ALWAYS replace waterpump when doing opti - also make sure it mated to engine tight.
Old Jun 3, 2007 | 04:50 PM
rubyred93's Avatar
rubyred93
Disagree. The OE Opti is not fine....it's garbage. I can't stress enough that there is a huge difference between the OE unit and the DynaSpark....you get what you pay for.
As far as the water pump being the culprit and the Opti would be just fine if the pump didn't leak on it - you can't sell me on that. I just put a DynaSpark in my car after the 2nd OE unit failed after 3k miles....the waterpump was not leaking onto the 2nd failed OE unit. The pump was not original either, it had been replaced right along with the 2nd Opti. All aspects of the pump were excellent with no leakage, and still the OE unit failed.
I realize it's difficult to rationalize paying so much for the DynaSpark, but you can pay now or pay later. I've physically had both the DynaSpark in one hand and the OE unit in the other and I can't believe that I actually went OE the second time around. You won't regret purchasing a DynaSpark, but I can't say that about an OE replacement.
Plugs/wires/hoses are all items that should be taken care of while you have the front of the motor apart anyway, so that's a big "yes" to your question about those.
Forgot to mention - consider changing your serpentine belt if you haven't already. Early '93 is double sided, later '93 is single sided. The early '93 GM belts are no longer available, but I was able to hunt down a few out of West Virginia, so keep looking if you can't find them at first. Good Luck.
Old Jun 3, 2007 | 04:57 PM
corvette1989bham
Cool, thats why they sell both, I still say the OE opti is fine when the waterpump isnt leaking. If you prefer the Dynaspark, I am sure its a good unit too.
Old Jun 3, 2007 | 05:20 PM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
The belt is still available through your local Chevy dealership (got mine for $40.00 from West Chevrolet). I wouldn't start swapping out pulleys until you know for sure it's discontinued. Besides, how often do you go through a serpentine belt? If it ain't broke, don't fix it.
Old Jun 3, 2007 | 06:31 PM
JD'S WHITE 93's Avatar
JD'S WHITE 93
If you don't have an FSM I do for a 93 and can lookup or fax whatever you need. I do not have a scanner though.
Old Jun 4, 2007 | 06:53 AM
rubyred93's Avatar
rubyred93
Actually, Poughkeepsie Chevrolet in Poughkeepsie, NY says otherwise. The EARLY '93 belt is discontinued. This has been a topic of discussion here in the past as well. When I put the DynaSpark in about 3 weeks ago I took a look at the belt, and at 28k miles it was cracked in many places. Personally, I don't have a lot of faith in a cracked belt. Given the mileage of the car in the original post, I'd change out the belt while doing the Opti.
Old Jun 4, 2007 | 10:19 AM
H P Bushrod
Moderator Emeritus
I'd replace a belt with cracks too. I guess the dealerships here in the south must have a inside scoop on the early belts for '92's and early '93's. We can STILL get them here in Tennessee.
Old Jun 4, 2007 | 10:32 AM
onedef92's Avatar
onedef92
I can still get them in Louisville, KY. too. They run about $40 bones, but I get a 10% discount for Falls City Corvette Club Membership.
For the plugs wires, best deal I've found online is at www.GMPartsDirect.com They have a complete set of O.E.M. AC/Delco ingition wires for under $50 plus shipping.
For the plugs, I like the NGK TR-55 Double Platinums. You might as well replace the plug wire holders, too, as they're sure to be cracked from engine heat.
You can order them online for about $10 from Mid America Motorworks (MAM).
Old Jun 4, 2007 | 04:47 PM
rubyred93's Avatar
rubyred93
You southern guys are lucky if you can walk into your local dealer and buy an early '93 belt. I had to wait 4 days and pay $55.00 per belt (yeah, I bought 2 of them just to have a spare).
Somehow I feel violated....
Old Jun 4, 2007 | 11:15 PM
H P Bushrod
Moderator Emeritus
Man...that's just wrong ($55.00). Hang in there Bro.
To 93 LT1 won't start
Old Jun 10, 2007 | 04:08 PM
josephbs's Avatar
josephbs
Default Thanks!
Thanks to each of you for your input and advice. I've decided to replace everything and spend all of my grocery money for the next three months doing so. Since the twins are still on the tit and my wife could lose a few pounds, I think this will work out nicely. I will be scheduling two business lunches everyday to maintain my girlish figure.
I'm thinking about selling this thing soon.
1993 Ruby Red 40th Anniversary Edition
Automatic, 170K miles, cold A/C, many new parts and upgrades including:
New tires
New Clarion CD/MP3 system
New fuel pump & filter
New ignition system (Opti-wires-plugs-coil-module)
New water pump and thermostat
New heater fan
New battery
New brakes
Any takers? What do you think I can get out of it? Enough to buy a new mustang?
Old Jun 10, 2007 | 04:51 PM
jetmech09's Avatar
jetmech09
Default opti
opti opti opti
Old Jun 11, 2007 | 01:29 PM
onedef92's Avatar
onedef92
New tires
New heater fan
New battery
New brakes
Have you tested your ECM?
