Behind Rear Compartment
Old May 30, 2007 | 05:06 PM
The Beep's Avatar
The Beep
Default Behind Rear Compartment
The 85's going in for paint (finally). I need to remove the rear wing as that's being painted separately.
Does anyone know how to access the area underneth the rear deck behind the gas door (there are wing mounting nuts there that must be removed) either through the rear compartment or through the tail lights?
Old May 30, 2007 | 05:45 PM
SCCA VETTE's Avatar
SCCA VETTE
Tail lights would be the only way. U can not access the back of the car through the inside of the car
Old May 30, 2007 | 11:48 PM
The Beep's Avatar
The Beep
OK. Tail lights it is. Thanks for the info.
Old May 31, 2007 | 01:20 AM
matrix040's Avatar
matrix040
tailights, good luck
To Behind Rear Compartment
