LT 1 Auto hard acceleration Question
Old Jun 4, 2007 | 11:38 AM
steve mulherin's Avatar
steve mulherin
Default LT 1 Auto hard acceleration Question
When you are makein a pass at the track or just getting it on for the hell of it in your automatic, do you manually shift through the gears of leve it in Drive?
Old Jun 4, 2007 | 11:40 AM
NEVRL8T's Avatar
NEVRL8T
Leave it in drive.
Old Jun 4, 2007 | 11:46 AM
JakesterUK's Avatar
JakesterUK
For running the 1/4 I've experimented with both leaving it in drive and launching at 1,200 rpm and launching in 2nd, again launching at 1,200 but then shifting into drive 2/3rd down the track (at about 5,500 rpm just before the rev limiter kicks in).
I've found I'm quicker everytime with launching in 2nd
Old Jun 4, 2007 | 07:18 PM
C4DERF's Avatar
C4DERF
Originally Posted by TheAngelOfDeath
Leave it in drive.
Might have some fun and turn of your traction control!!!!!
Old Jun 4, 2007 | 08:35 PM
wayne lowry's Avatar
wayne lowry
You are not launching in second, the car will LAUNCH in first gear no matter if you put it in first, second, drive or overdirve.
Leave it in drive
Old Jun 4, 2007 | 09:09 PM
aminnich's Avatar
aminnich
Leave it in OD for most driving. If I am running some really twisty backroads I might use 2nd or regular D for better control and easier on the brakes.
Old Jun 4, 2007 | 09:49 PM
RWD_tech's Avatar
RWD_tech
you are putting a considerable strain on the transmission when you downshift to brake the car. your best bet is to just leave it in drive
Old Jun 4, 2007 | 09:56 PM
aminnich's Avatar
aminnich
I don't downshift. Start out in 2nd or D and keep it there. Better than having it constantly shifting gears as I run thru 'twisties'.
Old Jun 5, 2007 | 12:40 AM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
At the drag strip, put it in D (3rd), not OD...let the car shift itself...don't forget to turn off the ASR...
To LT 1 Auto hard acceleration Question
