Bose relay 1986- HELP!
Old Jun 7, 2007 | 11:39 PM
Brenda1's Avatar
Brenda1
Default Bose relay 1986- HELP!
Hi Guys. I tried to test my Bose relay today but could not dig it out. I removed the kick panel and followed the appropriate wires to locate the relay. I tryed to pull it down just like a back issue of Corvette fever instructed me to do but it seems stuck. I do not want to pull to hard and break something....is there a trick to removing this part. My battery is discharging and I fear the relay is stuck in the open position. Thanks for your help!
Old Jun 7, 2007 | 11:52 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
The relay is attached to the side of the dash support brace with a screw. You'll need to get your fingers on the connector to unplug and pull the wire and connector down. Plug in a new one and leave that other SOB right where it is.
I have a breadbox delete, so for me it was somewhat easy access.
