Octane Booster?
Old Oct 25, 2001 | 02:26 PM
GoodbyeGirl's Avatar
GoodbyeGirl
Cruise-In III Veteran
Default Octane Booster?
Is using Octane Booser :bs ? Since my 383 Stroker rebuild the mechanic told me to use it or the car could ping. For the first time, last fill-up I didn't use it and noticed no difference. What's the advantages/disadvantages of using it?
Old Oct 25, 2001 | 02:56 PM
RatRacer's Avatar
RatRacer
Default Re: Octane Booster? (GoodbyeGirl)
If your car does not ping on premium gas you are fine without it.
Old Oct 25, 2001 | 03:05 PM
pablocruise's Avatar
pablocruise
Default Re: Octane Booster? (Cam Potter)
Agreed. An engine only needs one point higher octane over the level where it "pings". Any higher might be unnecessary. An engine could ping at 87 for example, and a person could put 103 race octane but no horsepower is picked up because of the extra 5 octane points(one for the pinging and four difference). I suspect the ecm would retard accordingly. no? Amazing little motor ya got there BTW!
Old Oct 26, 2001 | 01:41 AM
Bill Reid's Avatar
Bill Reid
Default Re: Octane Booster? (89 Paul in cal)
Yep, race gas or anything above premium pump gas does not add power... it only retards ignition of the gas in the cylinder during the compression/fire stroke. The ECM will retard timing if detonation is sensed. If you don't here it and the car does not set any codes then I wouldn't worry about it. By the way, I have found Octane Boosters as they are sold in your local auto parts store to be completely useless. Only race gas has worked for me ( 5 gallons minimum of 101 added at fill up with 92) in eliminating knock until I have the an EPROM with the correct timing installed. Damn domed pistons :D
Old Oct 26, 2001 | 01:54 AM
GRX's Avatar
GRX
Octane Booser? I'll drink to that! :cheers:
Old Oct 26, 2001 | 06:59 AM
CowboyNVette's Avatar
CowboyNVette
Default Re: Octane Booster? (GRX)
:lol: :lol: :lol: :lol:
Old Oct 26, 2001 | 08:54 AM
FU's Avatar
FU
Race Director<br><img src="/forums/images/ranks/7k-10k.gif" border="0">
From: HOME OF THE FREE. BECAUSE OF OUR BRAVE. Babylon NY
St. Jude Donor '06 thru '20
Your mechanic friend is probably telling you to use octane booster because the compression in your motor is thought to be to high. The use of octane booster is to create a comfortable margin so detonation dosen't start destroying thing's like head gasket's, piston's and bearing's. Just because the car dosen't run any better without the octane booster is no reason to say that detonation is not occuring. I put in 1 gallon of race fuel to a full tank of the high octane gas. The safe thing to do is to keep putting in the octane booster or preferably 1 gallon of race fuel per tank. Hope this help's.
Old Oct 27, 2001 | 03:14 AM
Ezgoin721's Avatar
Ezgoin721
I may be wrong here, but as I understand it, even the best octaine boost you buy in the auto store will typically only add 3 to 5 points. It takes 10 points to increase one count of octaine, ie...from 92 to 93 octaine! Therefore, it would take 2-3 cans of boost to up one tank of gas by one number of octaine!
Someone tell me if I'm wrong!
Old Oct 27, 2001 | 05:09 AM
Aman's Avatar
Aman
Default Re: Octane Booster? (Ezgoin721)
A basic question - what does 'ping' mean in relation to an engine?
Thanks.
Al.
Old Oct 29, 2001 | 11:09 AM
GRX's Avatar
GRX
Seriously, I've found that my plugs develop a red hue to them after using certain boosters. Misfiring can then occur because IMO this hue is electroconductive and starts shorting the plugs. My .02 :flag
Old Oct 29, 2001 | 03:50 PM
ghall's Avatar
ghall
This is just an opinion--but i have done some research on this subject.Octane booster is a waste of money,if you follow the manuf.'s recommendation---it will add very little to your octane rating.If you really want to lower your chances of knock---splash a gallon of xylene or toulene with a fill-up and i promise you that you will be happy with the results.
I also disagree with the fact that ---if you can't hear knock or ping that it is not bad--there could be damage occuring before you get to the point of hearing knock.Octane is your friend.
Geoff Hall
Old Oct 29, 2001 | 04:10 PM
Nathan Plemons's Avatar
Nathan Plemons
The question here that hasn't been asked, what compression is your motor running? With a stock compression of 10.4:1 (LT1) you can obviously run premium without any trouble.
Old Oct 29, 2001 | 07:15 PM
TurboVette's Avatar
TurboVette
Default Re: Octane Booster? (ghall)
I agree with GHALL. :yesnod: I've used Xylene (117 Octane) for years with great results. I buy it by the drum every spring.
Most GN owners (turbo guys) are familiar with this stuff.
Old Oct 29, 2001 | 07:22 PM
FU's Avatar
FU
Default Re: Octane Booster? (TurboVette)
Hey their Michael !! How's that beautiful Turbo Vette running ?
Old Oct 29, 2001 | 07:39 PM
John Row's Avatar
John Row
Default Re: Octane Booster? (Aman)
Ping is the result of the expansion of the combustion mixture before the proper position of the piston is reached. In simple terms, the mixture is expanding while the piston is still on the upstroke.
Problems caused: the piston, connecting rod, heads and crankshaft are subject to extreme pressure (and stress) while still on an upstroke. Extended pings will usually result in one of these parts failing.
Higher octane causes the fuel to burn/explode slower allowing the piston to reach the proper position before maximum pressure is reached. Retarding the spark does the same thing by igniting the mixture later in the cycle and also reducing power.
There are probably a hundred things that cause pinging, none of them are good for your engine unless it's a diesel.
I hope this makes sense.
Old Oct 29, 2001 | 10:14 PM
Bill Reid's Avatar
Bill Reid
Default Re: Octane Booster? (Nathan Plemons)
LT1 and LT4 (10.8:1 compression ratio) had superior engine mangagement systems than did an L98. High compression ratio's can be made streetable... you just have to know how to correctly tune them. GM smacked a home run with the LT4 and its high compression ratio. I've been told by more than one LT4 owner that when they crank over their car it knocks during initial startup. From what I understand the computer advances the timing initially and does a check of the knock sensor(s) to verify the circuit is in working order.
Old Oct 29, 2001 | 11:07 PM
Aman's Avatar
Aman
Default Re: Octane Booster? (John Row)
John - thanks for a very clear description of ping.
This is probably a question for a new topic - but...
does the Engine Management System sense this may be going on and try to alter the speed of the pistons, or something?
Just plain old curiousty! :)
Al.
Old Oct 30, 2001 | 12:56 AM
TurboVette's Avatar
TurboVette
Default Re: Octane Booster? (FrankUrbinati)
Hey Frank,
It's been a great year, thanks. :)
I hope to see you in BG again next year.
Old Oct 30, 2001 | 01:07 AM
TurboVette's Avatar
TurboVette
AMAN, actualy the knock sensor "listens" for 5 to 6Khz frequency (knock) then the ESC signals your computer. The ECM will retard your timing at a pre-programed rate to spare your motor.
To Octane Booster?
