700R4 Problems
Old Jun 20, 2007 | 10:22 PM
65 fi's Avatar
65 fi
Default 700R4 Problems
I am a Corvette owner with a son who is experiencing problems with his 700R4 transmission. He owns a 1990 IROC Camaro. He has a ZZ383 engine and the transmission has a shift kit and 2800 stall converter. He is having a problem with shifts from first to second. The transmission does not shift from first to second until it hits around 5000Any ideas? It had been working properly until recently. The mechanic he goes to is stumped as well. Thanks for any help with this one.
Old Jun 20, 2007 | 11:47 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Give Pete K a PM on this. He is our resident expert.
Old Jun 21, 2007 | 07:12 AM
RichS's Avatar
RichS
TV cable set too tight?
Old Jun 21, 2007 | 07:15 AM
toptechx6's Avatar
toptechx6
Sounds like a governor problem to me but as mentioned Pete K. is "THE MAN" I'm sure he will get you pointed in the right direction when he check in, good luck.
Old Jun 21, 2007 | 02:05 PM
Quarklt1's Avatar
Quarklt1
Cruising
Default Quarklt1
sounds like the plastic gear on the governor is striped pull the cover off and check
Old Jun 21, 2007 | 02:08 PM
Pete K's Avatar
Pete K
Was the shift kit a B&M or Transgo?
Old Jun 22, 2007 | 12:26 AM
65 fi's Avatar
65 fi
The shift kit that was in the transmission was a Transgo. The mechanic pulled it out. I don't know what he replaced it with but I would imagine the same. He did put a Corvette valve body in. Also, the mechanic had installed eight heavy duty clutches and I believe thicker bands. I am expecting an e-mail from the mechanic with a list of what was done. I can forward it upon receipt. Martin
To 700R4 Problems
