Emissions Help - Az
Old Jun 26, 2007 | 08:54 PM
Dr_737's Avatar
Dr_737
Default Emissions Help - Az
Hope you guys can help.
Failed the AZ DOT Emissions Testing today. Only Mod done to the vehilce is a catback exhaust system, consisting of an X/H - pipe and Dynomax Mufflers. She is a 1992 with only 31,500 miles on her.
Test results were:
Hydrocarbons (HC) in grams/mile:
vehicle: 3.60
standard: 1.0
Result: Failed
Carbon Monoxide (CO) in grams/mile:
vehicle: 58.79
standard: 12.0
Result: Failed
Oxides of Nitrogen (NOX) in grams/mile:
vehicle: 1.41
standard: 2.50
Result: Pass
Anyone have any ideas as to how to lower HC and CO? Anyone have a stock catback for a 92 or 93 for sale?
Thanks for help help.
Old Jun 26, 2007 | 08:59 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Wow, you are way off. I have a complete LT1 system, but are you sure someone didn't gut (or remove) the cats? Are you showing a check engine light? Is it running rough?
Old Jun 26, 2007 | 10:25 PM
CJWC4AZ's Avatar
CJWC4AZ
Default Failed emissions
I'm in Mesa, AZ & failed twice. Time was running out & I couldn't work on the car before the tags expired. Took it to Exotic Muscle in Tempe, they made some adjustments, etc., then I passed. Their number in Tempe is 480-967-4222. Ask for Merle or Trevor. Good luck to you.
Old Jun 27, 2007 | 12:33 AM
Dr_737's Avatar
Dr_737
Thanks for the reply guys..
I do have a check engine light. It comes on, then goes out. Never steady. Car runs great, not rough or anything. Just had the 30,000 mile check/tune up done on it. No issues
Any other ideas?
Old Jun 27, 2007 | 12:37 AM
zr1fred's Avatar
zr1fred
What's the codes on the check engine light. Take a paper clip and short the two top right pins on the adl connector, or go to Autozone and they will read the codes for you.
Old Jun 27, 2007 | 06:12 AM
toptechx6's Avatar
toptechx6
The catback exhaust has nothing to do with failing, address your DTC first, that may do the trick. Seat of the pants "running good" means little because they often run great when rich, good luck.
Old Jun 27, 2007 | 10:58 AM
redwing76's Avatar
redwing76
Do search on the net the info is there.
You're running rich. Poor mileage?
Old Jul 10, 2007 | 02:02 AM
Dr_737's Avatar
Dr_737
incase you guys were wondering:
After looking into the codes and so forth, i did come up with a code 43, which is a knock sensor. Checked the resistance of the sensor and all was good. Cleaned the connection with electrical cleaner and check engine light when away.
Re-took the emissions test and Failed a second time.
HOLD ON TO YOUR SEATS....
Finally i decided to take it to a mechanic. 1.5 hours and a 130.00 dollars later the mechanic tells me she's is running like a fine tuned kitten. He asks me two questions; what testing facility did i use and was it a young person performing the test or an older person?
After answering his two questions, we take it to the same testing facility. The mechanic kindly asks for a manager. The manager, a female, says she will run the car thru the test.
I PASS with flying colors.
Appartently, you can mis-drive a standard shift vehicle to make it fail. I am currently trying to recoup my 130.00 from the state of AZ
Old Jul 10, 2007 | 04:16 AM
toptechx6's Avatar
toptechx6
Thanks for the update, seems that many who post looking for help forget to follow up after the problem is resolved. Happy to hear you passed, best of luck recovering your unnecessary "repair" expense.
Kudos to the technician who figured it out, many would have wasted more money throwing parts at a problem that never existed.
Old Jul 10, 2007 | 08:13 AM
zr1fred's Avatar
zr1fred
WOW, that is a strange one! Glad it worked out. Was the second failure as bad as the first?
Old Jul 10, 2007 | 11:48 AM
redwing76's Avatar
redwing76
It can make a difference.
Years ago a friend took his new Nissan to a test station in LA Ca.
I went with him, he said its a new car it will pass. It didn't.
At the exit door this guy comes up with a flyer, that says, 2 blocks down on the right we'll get it to pass.
The folks in the area rented every garage within 2 miles to install test machines in.
There were more cars being tuned to pass in a backyard garage than in the state test facility.
$35.00 later back in line and the new car passed.
What a racket.
Its been said that in the next 10-20 years 1/3 of all the air pollution
in California will be from China.
It isn't dirty cars thats ruining the planet its over population.
To Emissions Help - Az
