boat with vette engine submerged.
Electrical is a different matter, you may have to replace those items. Trying drying those items out first, or use compressed air to remove as much water/moister as possible. Give it a try at starting. Trouble shoot the non start areas....spark, fuel, injectors etc.
Good Luck,
Good Luck,
with the posts regarding purging the engine ASAP!!! to prevent problems. The electrical is a different can of worms. I'd consider all electronics shot, wiring harness's suspect. I've known of several aircraft that ditched in fresh water and were rebuilt with the exception of the electrical/electronic systems which were totaly replaced due to suspect reliability.
DoDo happens. I had a Chris with twin diesels that sank. Did what Marker said. Course I didn't have a lot of electrical stuff to worry about. After clean up they were fine.
___________
He didn't say he sank his; the water rose and it "submerged".
I'm trying to figure out how.....
Larry
code5coupe
____________
not easily impressed....
I hope you can save the boat and motor!
If you have a boat that is moored (Tied to the pier) you need to lengthen the lines as the tides rise, and shorten them as the tide falls. Usually around here (MD) we get flood tides in November. The water comes up 2 or 3 feet above the piers, you need to stay with the boat almost all day as tides change.
It is possible that the OP's boat was moored to a very solid object (pier, etc) and rising water caused the submersion...I didn't think of that while I was going through the possible scenarios.
That would be a bummer....
Larry
code5coupe
__________
Often wrong, never in doubt....
I don't have any experience with water logged 4 cycle motors, but I do with 2 cycles.
I had borrowed my brother's snowmobile so a friend and I could go trail/lake riding.
A group of 5 of us were on a lake. Going across the lake, I could see a tent in the ice maybe 100 ft in front of me (I was second in line).
The first sled hit it and went right over and kept going. I saw the ice open up, but I was going too fast to turn away, stop, or completely avoid it. I hit the ice, the skis skimmed over, the track hit the water, but I was able to power up and over the opening. My buddy right behind wasn't as lucky. He slowed down, but not enough, and drove the skis right into the opening. He jumped off, and the sled nose dived in, but the tail section remained out of the water by about 1 ft.
Engine, tank, and seat were all submerged.
About 2 hours later, the 5 of us got up the nerve to fish the sled out. Luckily it was on a sand bar in about 3 ft. of water.
We got it out, towed it to a local gas station, put it in the bay overnight.Opened the tank, and no water had made it's way into the tank. Lucky.
Next, took the plugs out, and pulled the rope about 100 times to flush out the water. Let it sit overnight to dry up the electronics.
Next day, Put the plugs back in, and pulled on the rope a few more times. It started. I couldn't believe my luck. I couldn't sleep the previous night thinking about what I would tell my brother.
Actually the thing ran pretty good. Couldn't tell it had been submerged.
(I still had a tough time telling my brother about it, but he was actually quite calm about it, and he never had a problem with the sled after that)
So keep your chin up. You may get lucky with just a fluid change.
Fresh water ain't the end of the world to these things, but get it cleaned up quick, before any corrosion can start.
Good luck.
I'm with those who say drain the oil and fuel, put in fresh oil and fuel, run the engine until it is up to temp, drain the oil and fuel, refill, and you should be good to go(enginewise).
The rest of the boat, electrics included, will be another story.
Larry
code5coupe
__________
