Decisions...help!
No, but don't be discouraged by it. The early C4s have 230-250 hp, but can run very low 14s in the 1/4, which is competitive with the 280-300hp imports of today. This is due to better gearing and a broader power curve. Peak hp doesn't mean sh*t at the dragstrip. A 300hp Mustang GT will beat it though with a decent driver.
Fuel economy is good to keep in mind. The C4s can get great mileage. My 85 with a few mods averages 26 mpg on the freeway and do 500 miles on a tank. You won't touch that in the C3.
My dad refuses to race me cause he said it will just be sort of sad since he has so much experience with racing and i dont lol
So usually driving the places i drive to i get 16 mpg, and i only filled up once this week but i didnt get to use it as much as i wanted too since the mechanical problems and everything.the other one is getting transported and will be here next week, i cant wait to see it
It can also be leaking at the calipers or brake lines, these are usually more obvious, just look for the wet spots.
If you don't fix those you might find yourself fixing the whole front end pretty soon, AND the brakes.
Even if you did, the junkyard parts would be almost as bad or worse as what you're starting with.
lolThe junk yard i talked too does have c4 interiors actually, but their pretty beat up. haha my dad said exactly what you said about what happened.
If i pass by the mechanic today i'll take pictures under the hood
I bought an 87 with 45k miles, but I accepted that a lot of rubber would need replacing and plastic parts would crack. I don't mind it that much.
In 9k miles I've replaced:
-Radiator and upper and lower hoses.
-Transmission pan gasket and filter.
-MAF Sensor and relays.
-Oil Temperature Sensor.
-2 Digital Dash panes.
-Brake Master Cylinder and Front pads.
And probably more stuff I can't remember while at work. It has been about $650 over 1.5 years. Keep in mind, the former owners ate a lot of bills to keep it in the shape it's in. This car was driven and maintained over it's life.
CC is right about cars with low mileage. It IS a double edged sword. You can get a nice car that will provide loyal service for years, or one that was left in a corner for a few years that's ready to fail. It's best to have low mileage that you can prove was accumulated at a steady rate over the years, with regular time based maintenance. On seldom driven cars, mileage is less relevant for parts and fluid replacement intervals.
Brake m/c $130
3 wheel bearings x $150 each
4 ball joints x $80 each
bushings $190
fuel pump $60
injector cleaning $100
replacing dryrotted tires $600
clutch m/c $90
clutch slave $80
waterpump $40
ps pump $80
steering rack $200
ujoints $180
radiator $150
a/c compressor $220
a/c hoses $200
engine front/rearmain/pan/valve cover gaskets $70
Not to mention all the misc crap and the and hours and hours under the car.
Gotta love them low miles!
Brake m/c $130
bushings $190
fuel pump $60
clutch m/c $90
clutch slave $80
waterpump $40
ps pump $80
steering rack $200
ujoints $180
radiator $150
a/c compressor $220
a/c hoses $200
The problems on it when I bought it were the cooling system, intake gaskets, tires, bushings. But to be fair, a good chunk of that list will need to be done to all 23 yr old Corvettes.Just make sure to buy it from the other sucker that's done the work, so you don't have to.
Not that i dont expect any, just not as much
I havent checked up to see how its doing yet (the c4)
Its still at the mechanics since the brake incident
