Only starts on second try????
Old Oct 30, 2001 | 09:40 PM
joseph p's Avatar
joseph p
Default Only starts on second try????
Bought '89 coupe 2 months ago. Replaced fuel pump, fuel filter, adj. fuel reg. (42 psi), cleaned and set TPS, IAC, and throttle body, removed and cleaned rails and injectors,new coil, cap,platinum plugs, wires, set timing 6BTC, new air filter, flushed and filled coolant, added lucas fuel treatment and new battery. All of which were added because car has98K on it and I wanted these parts in good shape from start of my ownership. The car will not start on first turn of key ( tried waiting w/key on for 20 seconds) no matter what I do, but seems to start on second try regardless of how short a period the first try was...it just won't start till second try!!???
Any suggestions?
Old Oct 30, 2001 | 09:45 PM
GS 163's Avatar
GS 163
Default Re: Only starts on second try???? (joseph p)
I cant really help you , but welcome to the forum. Im sure you will get alot of help from everyone else though.:)
Old Oct 30, 2001 | 10:13 PM
joseph p's Avatar
joseph p
Thanks, I hope so. This is very frustrating. :confused:
Old Oct 31, 2001 | 11:31 AM
joseph p's Avatar
joseph p
Anybody??? Anything???
Old Oct 31, 2001 | 06:01 PM
BaseballDude's Avatar
BaseballDude
Could be the contacts (brushes) on your starter going. I had this exact same condition a little over one year ago. I had the starter rebuilt ($91 - much cheaper than a new LT-1 starter) and the problem went away immediately.
What happens is that you turn the ignition and the brushes do not make enough contact on the first engagement, so you get a nice "click" and nothing else. On the second try, they are in a bette position to more fully engage and you get a start condition. It's a frustrating condition, especially when you know the battery and charging (alternator) systems are functioning properly. Yeah, I even swapped in a new battery thinking that would cure the ills.
Good luck!
[Modified by CaliforniaLT-1, 2:02 PM 10/31/2001]
Old Oct 31, 2001 | 06:32 PM
1MoorTym's Avatar
1MoorTym
Did the car start on the first crank before you replaced those parts?
The reason I ask because there is an interesting article in the December Corvette Fever in the 'wear and tear' write in section.
The jist of this letter/reply concerns the programming of the 89 prom which delays producing injector pulses for seconds after cranking the engine. The author theorizes that this was done to cure a hot start problem with emisions testing and to remedy fuel injector leak problem on 85-88 cars which caused them to have excessive fuel on start-up.
My own 89 will sometimes start on first crank and always start on second.
Old Nov 1, 2001 | 12:34 PM
joseph p's Avatar
joseph p
Default Re: Only starts on second try???? (1MoorTym)
It doesn't seem starter related...it cranks, it just won't turnover and start until second try. Don't know if it did it before "tune-up" because all was done within first week of ownership.
Injector pulsing seems like it could be the area to check, or should I consider two starts as normal operating procedure for these cars??
Old Nov 1, 2001 | 12:38 PM
GS 163's Avatar
GS 163
I wouldnt consider two starts as normal. Mine always starts on the first try no matter what. Or at least it did until my starter started crapping out on me.:)
Old Jun 23, 2022 | 10:58 PM
pete315's Avatar
pete315
I know this thread started 21 years ago but I just picked up a 89 Corvette from distant relative. Car sat for 6 years. Running on 6 cylinders when I got it. Also the heater core was leaking real bad. Change the heater core ( not that bad of a job) and installed all new fuel injectors, plugs, cap,rotor, gas filter, fuel pump relay. Car runs great now. My car also starts only a second try. No matter if first start of day or it’s warmed up and I just turned it off. Fuel pressure is perfect. Does not bleed down. I get 40 psi when I turn key to on and pump goes on for 2 seconds. Did you ever find the cause? Just curious. It really doesn’t bother me that car starts on 2nd attempt.
Old Jun 25, 2022 | 04:55 PM
yaknow's Avatar
yaknow
I've also got an '89, has always start on 2nd attempt. I have changed everything, except the starter, including ECM with no change in starting.
Old Jun 25, 2022 | 05:41 PM
BillDurant's Avatar
BillDurant
make sure you turn on the key to power let the pump do it thing then start
Old Jun 25, 2022 | 06:29 PM
RWDsmoke's Avatar
RWDsmoke
If I recall correctly the early ECM's did not fire the prime fuel pulses until after six ignition pulses. It was an annoyance especially on the first start of the day. I used to bump the starter, wait three seconds then had an instant start. When tuning I used to set it to prime on the first ignition pulse. Also if the injectors have been changed and the voltage offsets don't match, the voltage drop while cranking can cause a slight lean condition,. Check your battery voltage while cranking. Sometimes a new battery to replace a tired one makes a big difference.
Old Jun 25, 2022 | 11:10 PM
pete315's Avatar
pete315
Good to know. Thanks
Old Jun 25, 2022 | 11:15 PM
Tokuzumi's Avatar
Tokuzumi
If this is true, it truly fits the GM narrative. "The terrible execution of great ideas." Well, maybe this idea isn't great, but take something great, and ruin the experience with a death by a thousand paper cuts.
I can't help but laugh reading this.
disclaimer; 2/3 of my vehicles are GM products
To Only starts on second try????
