Quick question about gas
Old Jul 13, 2007 | 12:49 AM
Gen7654's Avatar
Gen7654
2nd Gear
Default Quick question about gas
I recently bought a 1988 corvette. I recently fixed a steering fluid leak, so now I have the car running. But I wanted to know what octane gasoline do you guys use on your C4's. Or if one of you guys has the owner's manual, what's the manufacturer recommended octane?
Old Jul 13, 2007 | 12:55 AM
80sRule's Avatar
80sRule
87 Octane.
Just get any brand on the Top Tier Gas list and your good. LINK
Old Jul 13, 2007 | 03:49 AM
85 500 horse's Avatar
85 500 horse
You can use a minimum of 87 octane. The timing will be automatically retarded a bit via the computer, due to the lower octane and power will be reduced a bit, but nothing detrimental will occur. If you should hear pinging, fill your tank with a higher octane as soon as possible.
Actually, very slight pinging (barely audible) is optimum, but most
people don't like to hear anything (me included), so if you dump a few gallons of 93 in the tank, it should go away.
Old Jul 13, 2007 | 11:29 AM
Gen7654's Avatar
Gen7654
2nd Gear
Alright guys, 87 it is. Thanks for your help.
Old Jul 13, 2007 | 01:21 PM
rws.1's Avatar
rws.1
an 88 is approaching 20 years old. As cars age octane appetite often increases. So whehter it runs without knock on 87 now depends on the condition and mileage of the engine.
As engines accumulate mileage they can also accumulate internal carbon deposits and varnish. Deposits that form on the pistons and combustion chambers can change the shape, surface and volume. Rings wear, permitting blowby, etc etc.
To this extent compression and other changes can induce pre-detonation (ping or knock)
While a new engine may be fine on a diet of 87 octane, an afflicted engine may require an increase in octane. a colleage has a 94 VW Jetta with 190K on the odometer. When new and until it hit 100K, it was happy on 87. As it past 120K it needed 89 0ctane. Around 170K miles it was no longer knock free on 89 and now happily only runs on 92-93
Old Jul 13, 2007 | 02:49 PM
80sRule's Avatar
80sRule
Originally Posted by 80sRule
87 Octane.
I should mention, mine is an 87 Vert with 54k miles. I always run Shell 87 or 89. Absolutely no issues with pinging. No oil consumption or leaking and I run Mobil 1 5w30.
Old Jul 13, 2007 | 03:52 PM
wmupaprmkr's Avatar
wmupaprmkr
Cool Hand Luke of W MI
I run 93 in teh 92 LT1 as directed in teh owners manual...
Old Jul 13, 2007 | 05:21 PM
dclafleur's Avatar
dclafleur
Owners manual indicates 87, it works fine as long as you don't get any knocking or pinging, no worries. If you hear some step up a grade.
Old Jul 13, 2007 | 06:03 PM
Aardwolf's Avatar
Aardwolf
My '88 manual says to use premium or there will be power loss. I track mine so it always has premium in it.
Old Jul 13, 2007 | 10:29 PM
Matt383's Avatar
Matt383
From: 2003 Points Champ Great Lakes Corvette Challenge; 2006/2007 Winner MSD True Street
why would you use 87???
The computer will adjust, yeah
By why would you freaking want your car to adjust to 87???
It's a vette, not a school bus.
I drive a vette, it looks cool, but I intentionally retard performance because I want to save a few bucks????
Com' on guys!
Matt383
Old Jul 13, 2007 | 11:46 PM
80sRule's Avatar
80sRule
After reading my manual, I can say I'm going back to premium. Reading page 2-2 proved it to me.
Old Jul 14, 2007 | 01:55 AM
C4boy's Avatar
C4boy
Do you guys with stock L98's honestly notice a difference in Octane or brand? (and I'm not trying to start a pissing contest here, just curious)
Old Jul 14, 2007 | 02:18 AM
coltcarbine's Avatar
coltcarbine
Me too, 'cept mine's a '95.
Old Jul 14, 2007 | 08:59 AM
Matt383's Avatar
Matt383
Not going down that road because my vette is altered so it is not a fair answer on my part.
I can say that my truck manual suggests that when towing or doing other stressful things with the truck I should use a higher octane.
This would suggest that the engine needs more octane under load.
So my rationale would be if you don't put your vette under load (WOT a lot) you may not notice.
My two cents.
Matt383
Old Jul 14, 2007 | 09:11 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Why is this optimum? Explain.
Old Jul 14, 2007 | 11:12 AM
Aardwolf's Avatar
Aardwolf
The knock sensor hears ping that the human ear cannot.
I track mine and do not want to risk damage from saving a little bit in gas cost. I would like to datalog the car to see when there are knock counts but I do not have that equipment yet. So better safe then sorry for me.
Old Jul 14, 2007 | 03:03 PM
wes0826's Avatar
wes0826
I have an 89 with the L98 and never run anything less than 91. If I can get the 104 Sunoco I'll always buy that. And I get much better gas milage with a higher octane. Just made a run to Richmond and back from Cincinnati and averaged 28.4 with 93 octane.
To Quick question about gas
Old Jul 14, 2007 | 04:50 PM
Matt383's Avatar
Matt383
Now to the other extreme
If your l98 is even close to stock you don't need the 104.
That is just wasting your money.
Your car was designed for premium, not race fuel 104.
The only way an engine can benifit from 104 is having higher compression.
If you have stock compression you will never benefit from 104.
Sunoco 100 costs $6.47 a gallon around here.
Why use it if you don't need it?
Save your $$$ and stay with 91 - 94 Octane.
My two cents.
Matt383
Old Jul 14, 2007 | 05:09 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
My 1989 owners manual says 91. Your heads are the same as mine so you should run at least 89. I mix 93 and 89 in the hot summer months 50/50 to approximate 91 octane and it runs very well. These engines evolved over time so a 1987 and say a 1990 can be very different.
Old Jul 15, 2007 | 12:56 PM
redwing76's Avatar
redwing76
Gas is like beer, you can't own it. Buy whatever is on sale at cheap chicken charlies.
87 89 91? I remember a time when it was 110 or nothing.
110 is red, the shizt they sell now looks like water, but it doesn't need lead to contain the burn rate.
Premium is a racket, it all comes in the same tanker, at the same time, from the same fuel depot.
