It isn't that hard, I disconnect my negative battery terminal when I did mine, get a 16mm flair line wrench and I think the other is a 20 mm wrench as a backup wrench, I just used a crescent wrench for my backup. Loosen the strap, the bolt holding it is a 10mm bolt, disconnect engine side first. Be prepared to have some gasoline drain out, I'd say have a bucket ready to catch it and let it gravity drain for a few. I've heard suggestions of wrapping towels around your arms to keep fuel from running down your back, also make sure you have goggles on.
Not hard, just annoying and even 87 octane fuel can irritate your skin.
Here's why it took me so long, rust, and lots of it.
So im thinking while its running, il pull the gas line fuse. This should help empty the gas.
also
Unscrew the gas cap.
Does every one agree with the first part, i dont want to mess any thing up..
Either start the engine and pull the fuse or let the car sit over night. Either way you need it on ramps before hand. You will get some gas out of the lines as soon as you break the retaining nuts loose. Don't worry about the gas cap.
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
An '85 doesn't have pre-cats, right? This should make it a lot easier to access. I know on stock LTx cars with the two main cats still in place, it's a bit of a PITA.
1. If the car isn't hot, place a rag near the fuel rail pressure schrader valve, and depres it till the pressure goes away. let the rag soak up the gas.
2. take off the gas cap, then put it back on.
3. Get an aluminum turkey pan from the market for about $3 and place a rag in the bottom of it, and put it in position.
4. use a 13/16 wrench on the filter and a 5/8 wrench on the fuel lines. wrap a rag around the filter fittings when you break them loose to catch residual.
5. Use the longest wrenches in those sizes that you can.
6. Pull the fuel line that goes to the engine forward to release the tension on the filter, and it will fall into the turkey pan.
7. Notice on the new filter which way goes forward, it's usually either the welded or crimped end of the filter.
8. Put the new filter on the rear line, and pull the front line again, line the line up into the filter, and release. **** the filter to line up the fittings, (be sure it's
not crossthreaded, because changing that fuel line ususally means selling the car) and tighten. Make them tight because theres no seal, you are crimping the
flare on the line.
9. turn the key on, wait for 2 seconds, then try to start it. it may take up to 3 or 4 tries to fill up the filter and build up pressure.
Reason: add content
I think the LT-1 cars have big pre cats and heat shielding in close proximity to the fuel filter which makes their cars more difficult than us L98 folks.
