back up lights
Old Jul 16, 2007 | 07:00 AM
VinceC4's Avatar
VinceC4
Default back up lights
Okay dumb question..where the heck are the back up lights on a '95? Are they the lights near the license plate? Had reason to back up last night in total darkness and realized for the first time, I had no lights...YIKES
Old Jul 16, 2007 | 07:10 AM
Mekanic's Avatar
Mekanic
Yeah, next to the tail lamps.
If your car is a 6 speed the switch that activates them is notorious for going out.
Check the fuse first.
Old Jul 16, 2007 | 08:30 AM
VinceC4's Avatar
VinceC4
[QUOTE=Mekanic;1561093104]Yeah, next to the tail lamps.
Check the fuse first.[/QUOTE
Yep a 6 speed..I will check it out..thanks for the info
Old Jul 16, 2007 | 08:34 AM
Mekanic's Avatar
Mekanic
No problem!
FYI if it is the switch, it is screwed into the transmission, on the drivers side, behind the slave cylinder.
And the switch is expensive
I hope its a fuse or bulbs for you, and not a switch like mine
Old Jul 16, 2007 | 10:12 AM
c4cruiser's Avatar
c4cruiser
There are also backup lights next to each rear side marker lamps that come on when in Reverse. They are tied into the same circuit as the backup lights so if they don't work, it's either a fuse (check here first!) or the switch down at the tranny.
Old Jul 16, 2007 | 10:45 AM
Mekanic's Avatar
Mekanic
wow! Since my switch is dead I didn't even know those were supposed to come on LMAO!!
Learned something new... now I can take a nap.. I've earned it
Old Sep 1, 2007 | 06:04 PM
IcemanZ06's Avatar
IcemanZ06
does anyone have a picture of the switch location or tell me where the fuse is? I have the same problem and I'm completely lost on this one.
BTW, How much is "expensive" for the switch?
Old Sep 1, 2007 | 07:53 PM
Da Mail Man's Avatar
Da Mail Man
Old Sep 1, 2007 | 10:07 PM
aminnich's Avatar
aminnich
Originally Posted by Mekanic
Yeah, next to the tail lamps. Well sorta next to there, but actually both sides of the license plate. And remove the license plate to get to the bulbs.
If an auto the switch is in the shift console. Fuse panel is visible if you open the passenger door and look at the side of the dash.
Hope this helps.
To back up lights
