trans problem at 125mph
Old Jul 17, 2007 | 10:25 AM
lange's Avatar
lange
Default trans problem at 125mph
the other day, I was full throttle in my 86 vette and when I got to 125, the car started to shift one gear up and down very fast like if it was searching for the right gear. I let go the throttle, got back to 70 and everything was perfect.
What could have happened? I drove it 4 more hours the next days and the trans seems okay (althought I haven't tried it again at 125)
Could the trans be going away or might it be electronic?
Old Jul 17, 2007 | 12:56 PM
Pete K's Avatar
Pete K
You can rule out the electronics. 86 transmissions have none.
Vettes and police cars had a special valve that allowed the trans to shift from 3rd gear(at wide open throttle) to 4th gear. More than likely the trans you have now is not a vette trans, but has been swapped from a different car during it's past. That is the normal reason for the symptoms you describe
Old Jul 17, 2007 | 01:09 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Was that 125 mph or kph?
Old Jul 17, 2007 | 01:13 PM
lange's Avatar
lange
125mph. 200kph.
At 125 it went up one gear and then very fast came down, and up, and down and up. Did that for 10 sec and I let it go.
First time that happens at that speed.
Old Jul 17, 2007 | 01:36 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
I'd GUESS you have a fluid problem, low or sloshing back away from the pickup/ bad filler gasket.
To trans problem at 125mph
