Oil changes... etc....
Old Nov 1, 2001 | 10:28 AM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
Default Oil changes... etc....
I just got a 93 LT1 with some mods.... headers, 3:73 gears, etc.... I changed the oil and used Mobil 1 per specs..... do I change every 3000 miles with synthetic or not ?... also, what about adding fuel injector cleaner or any additives ?..... thanks. :confused:
Old Nov 1, 2001 | 11:38 AM
fade_to_black's Avatar
fade_to_black
Default Re: Oil changes... etc.... (golfboy1)
I have heard you don't have to change synthetic but every 6,000 miles....just the filter. Although I still do it every 3,000 miles! I would use some injector cleaner if you just bought the car, I did when I first bought mine. Just to make sure every thing is up to par and cleaned out! :cheers:
Old Nov 1, 2001 | 12:32 PM
vader86's Avatar
vader86
Default Re: Oil changes... etc.... (fade_to_black)
use Techron fuel injector cleaner or STP, no knock off brands. I tried STP and even though i felt no difference nor heard any, it had to be good for the car.
NO OIL ADDITIVES
[Modified by vader86, 4:32 PM 11/1/2001]
Old Nov 1, 2001 | 04:08 PM
RedWhiteandBlue's Avatar
RedWhiteandBlue
JMHO, I still change the oil & filter every 3,000 miles. Synthetic oil will last longer before its viscosity breaks down, but any oil is susceptible to harboring combustion by-products and other contaminants, none of which I would want in my engine for very long...
Old Nov 1, 2001 | 06:58 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Default Re: Oil changes... etc.... (Barry94TorchRed)
Thanks all for the info.... I'll stick with every 3000 and a good injector cleaner :cheers:
Old Nov 3, 2001 | 12:24 AM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Welcome to the forum.
I changed mine about 5,500 thats when the light would come on.
To Oil changes... etc....
