Wheel clear coat removal.
Old 07-23-2007, 07:56 PM
Cessnapilot89
Cessnapilot89's Avatar
Default Wheel clear coat removal.
The clear coat on my OEM wheels is starting to show its age. I would like to remove is so I can polish the wheels up. Does anyone have any recommendations for what products to use?
Old 07-23-2007, 08:05 PM
corvette1989bham
corvette1989bham's Avatar
I have used aircraft stripper with gray scotchbrite to remove it, may take several coats / recoats
Old 07-23-2007, 08:42 PM
jrzvette
jrzvette's Avatar
Location: The reason time exists is so everything doesn't happen at once
If your car is a daily drive you may want to consider re-clear coating the wheels after stripping them. Polished aluminum looks better than chrome, IMO, but on a DD they can take a lot of work to keep looking that way.
Old 07-23-2007, 09:26 PM
champs65
champs65's Avatar
Along with several increasingly finer wet/dry grades of sandpaper. Ending at 1500 and my wheels are chromelike!
Old 07-23-2007, 09:51 PM
H P Bushrod
Moderator
H P Bushrod's Avatar
CI 5-6-7-8-9-10-11-12 Veteran
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23
I polish my wheels with Maas polish every two weeks or so. I works excellent on bare aluminum.
Old 07-24-2007, 02:43 AM
Cessnapilot89
What grit should I start off with? Should I use an electric buffer to polish?
Old 07-24-2007, 03:03 AM
86PACER
86PACER's Avatar
Indeed. Used it on my early wheels. Use a paint brush to apply and let it sit. The clear coat will dissolve. Then hose it off with a garden hose.
Old 07-24-2007, 06:49 AM
Atok
Atok's Avatar
I used Tal-Strip II Aircraft stripper. Two coats and they were bare. Then lots and lots of wet sanding, ending at 1500 grit, fine-cut compound, and finally Mother's Billet polish. If you keep the Mother's polish on a couple times a year they'll stay good.
Old 07-24-2007, 08:27 AM
champs65
champs65's Avatar
After using the stripper, I started wet sanding with 220.
I didn't use a buffer, don't see why you couldn't though. But, by the time I was at 1500, they were so smooth it probably wouldn't be necessary.
Old 07-24-2007, 09:55 AM
AGENT 86
AGENT 86's Avatar
If your going to go to the trouble of sanding, sand to 2500
Old 07-24-2007, 12:41 PM
Cessnapilot89
HI 86,
Those are beautidul wheels. Now I have an idea of what to strive for. I guess I know hwat my project for the weekend is.
Old 07-24-2007, 12:46 PM
rocco16
rocco16's Avatar
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
Acetone will remove the clearcoat.
Scotch-Brite will speed the process up.
Larry
code5coupe
___________
not easily impressed....
Old 07-24-2007, 02:19 PM
shakedown067
shakedown067's Avatar
St. Jude Donor '12-'13
If you use this stuff, make sure to have excessive ventalation (a large fan is recommended) and a proper mask. This stuff eats your bone marrow for lunch. I'm trying to find another paint stripper that doesn't have these nasty side effects.
Once you have them stripped. This stuff is great for sealing the bare aluminum. http://www.zoops.com/zoopseal.asp
I'm thinking about doing this to my old stock wheels and sell them.
Old 07-24-2007, 02:36 PM
NEVRL8T
NEVRL8T's Avatar
This is how someone over at Corvetteforums.com did theirs:
Okay, I was debating rather to buy new rims or polish my originals. My originals had corrosion that snuck under the Clear coat and were a bit banged up on the sides due to balance wgts. To save a little $$ I decided to fix up the original rims. Now for anyone interested on a "how to" I'll recap my day of rim polishing for you. This is not for the faint at heart, it took me the WHOLE day and I mean until dark to finish this project.
You'll Need
1-Paint Stripper (I used Stripeze) $6.29
2-Polishing Cream (I used Mothers) $6.99
3-000 Steel wool $1.99
4-Paint Brush (small, for applying stripper) $1.99
5-Plastic scraper $.99
6-Mothers Power Ball (miniature) $19.99
7-Garned hose and soap
Around $38 bucks, give or take a two. You could live without the Power Ball but it saved some elbow greese for sure.
First off, I didn't remove my tires or want to strip any of the silver paint on my rims. This made it a bit more difficult because I had to be real careful not to get stripper on the painted areas.
1- I removed the wheels off from one side of the vehicle to due two at one time (seemed to work faster)
2-Removed the balance wgts. (Took digital pics so that I put them on the same spot.)
3-I sanded and painted the balance wgts. While they were off
4-Clean rim and tire very good with cleaner
5-Applied coat of stripper and let sit for 15 minutes
6-scrubbed with stiff brush first, then a plastic scraper and finally with steel wool.
7-I had to repeat #5 & #6 two more times to get the entire clear coat off
8-hosed and scrubbed all remaining signs of stripper
9-Took mothers Power Ball and stuck it in the polishing compound
10-Polished rims with Power Ball for about 5 minutes, cleaned with water and soap.
11-Repeated #10 two more times
12-Cleaned with soap and water
13-dryed and put balance wgts. & Center caps back on
14-Put Armour all on tires and bolted back on the car.
Old 07-24-2007, 02:39 PM
bd2626
bd2626's Avatar
Agent86
Was this all hand sanded or did you use any type of power tools to help?
They look great!
Old 07-24-2007, 03:15 PM
AGENT 86
AGENT 86's Avatar
Originally Posted by bd2626
Agent86
They look great!
All hand sanded with a foam pad for backing the paper. The surface is not flat so power sanding could leave flat spots if your not careful. Headphones on and beer within reach, makes the time fly by.
Old 07-24-2007, 03:18 PM
bd2626
bd2626's Avatar
Thanks for the info!
What if anything did you protect them with?
To Wheel clear coat removal.
Old 07-24-2007, 03:23 PM
AGENT 86
AGENT 86's Avatar
Just Autosol polish so far, but I did buy some Flitz wax that I am going to try.
Old 07-24-2007, 03:26 PM
bd2626
bd2626's Avatar
So the results are just sanding or did you get to a point where you use a polish?
Old 07-24-2007, 03:55 PM
89 Bob L
89 Bob L's Avatar
Nice job!!!! I took the simple way out and had the rims chromed!!
Quick Reply: Wheel clear coat removal.
