Leaking Help!
Old Nov 2, 2001 | 03:51 PM
RadPolo96's Avatar
RadPolo96
Default Leaking Help!
Was washing mar car today and noticed that i had some leaking of water on the inside. I checked it out and it seems to be the same on both the driver side and passenger in the same places. I checked the targa and it was as tight as possible so it must be the weather stripping. Is this a common problem...if so how do i fix :confused:
Old Nov 2, 2001 | 04:30 PM
Red Dwarf's Avatar
Red Dwarf
Default Re: Leaking Help! (RadPolo96)
There are some drains (outboard) & one in the center, I think. Use a flashlight & look thru the screen below your wipers. Sometimes they get full of debris. :cheers:
Old Nov 2, 2001 | 04:55 PM
RadPolo96's Avatar
RadPolo96
Default Re: Leaking Help! (lou sylvestri)
Its on the driverside window and passenger.
Old Nov 2, 2001 | 05:27 PM
CBall's Avatar
CBall
Thanks for that tip. ;) I've been having similar problems!! :yesnod:
Old Nov 3, 2001 | 08:55 AM
89 Bob L's Avatar
89 Bob L
Remove the targa top for a couple of days. Use Silicone Grease, sold by GM as a weatherstrip conditioner. It works great and extends the life of the weatherstrip.
To Leaking Help!
