Spark PLug wire position?
Old Jul 30, 2007 | 05:14 PM
armybyrd's Avatar
armybyrd
Default Spark PLug wire position?
On my '88 C4 Im about to change the spark plug wires. My ? is in the haynes manual theres a diagram with the layout of thr cylinders and what number each is. Theres also a pic of a distributor and it says the blackened terminal is the number one spark plug wire position and theres an arrow going clockwise. Im assuming that since its going clockwise that its in order starting with the number one sp position? As in 1-2-3 and so on around clockwise til ur at 8?
Old Jul 30, 2007 | 06:32 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
1st-trash the haynes and get a FSM; 2nd: Try Searching (great tool) and you'll find the info
Old Jul 30, 2007 | 07:07 PM
armybyrd's Avatar
armybyrd
Wow, thanks for the help. Ya know I actually did a search for spark plug wire positions and nothing helpful came up. Whatever happened to people who actually had the answers to ppls questions replying instead of being a!!holes and always saying try the search??
If you happen to know the answer Id appreciate the input if not then dont reply
Old Jul 30, 2007 | 07:31 PM
94z07fx3's Avatar
94z07fx3
Bottom = front
The distributor orientation may not be right but the cylinder numbering is correct.
Old Jul 30, 2007 | 07:48 PM
juanathandavid's Avatar
juanathandavid
Originally Posted by 94z07fx3
Bottom = front
Right-click, Save-As
Followed up with a printout, lamination, and a thumbtack to the garage wall.
Old Jul 30, 2007 | 08:46 PM
armybyrd's Avatar
armybyrd
Thanks for the info.
Outta curiosity what would happen if the spark plug positionin was wrong and someone tried to start the car? Would any damage be done??
Old Jul 30, 2007 | 08:54 PM
Jims1988C4's Avatar
Jims1988C4
wow,
Old Jul 30, 2007 | 08:56 PM
Jims1988C4's Avatar
Jims1988C4
wow,thats no way to make friends,however,sometimes the search makes you very confused,esp, if your a newbie like me.
Old Jul 30, 2007 | 08:57 PM
94z07fx3's Avatar
94z07fx3
It depends on where the valves are. A bit of predetonation can destroy an engine. But if the spark is way out of phase then probably nothing too bad if anything would happen.
Old Jul 30, 2007 | 09:23 PM
armybyrd's Avatar
armybyrd
Does anyone know the spark plug wire positioning on the distributor cap of a '88 L98??
Old Jul 30, 2007 | 09:44 PM
94z07fx3's Avatar
94z07fx3
The pic I posted has #1 at about 6:30. Rotate that in your mind's eye counter-clock-wise to 5:30 and you've got the HEI positions.
Old Jul 30, 2007 | 09:57 PM
armybyrd's Avatar
armybyrd
So basically move each number to the right one plug?
Old Jul 30, 2007 | 09:59 PM
94z07fx3's Avatar
94z07fx3
Move them CCW one position 1 goes where 2 is 2 goes where 7 is etc.
(The diagram that I found was for the older points/cond setup.)
Old Jul 30, 2007 | 10:11 PM
armybyrd's Avatar
armybyrd
Ok gotcha.
By old setup do you mean as in an older car? Is there any difference between that and the hei setup besides the fact that their positioned differently?
Old Jul 30, 2007 | 10:15 PM
94z07fx3's Avatar
94z07fx3
Ok gotcha.
Yes I meant in the out moded points and condensor ignition system vs the newer HEI system. For the purposes of the diagram that I found there is no other difference.
Old Jul 30, 2007 | 11:40 PM
C4boy's Avatar
C4boy
If you save the picture, then view at a larger size, it may be easier to read. I wouldn't worry about asking questions, everyone has to start somewhere and not all are familiar with the ins and out of this bulletin board.
Everyone was a newbie here at some point.
Old Jul 31, 2007 | 10:21 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
If you do one wire at a time, you can't **** up.
To Spark PLug wire position?
Old Jul 31, 2007 | 10:49 AM
dclafleur's Avatar
dclafleur
Yeah but depending on the position and condition of the clips, that can be a pain in the neck with the factory routing, I couldn't get my beefy hands to the factory clips doing it one wire at a time.
Last edited by dclafleur; Jul 31, 2007 at 10:50 AM. Reason: I can't speel wurdz gud
Old Jul 31, 2007 | 11:21 AM
onedef92's Avatar
onedef92
Remove the fender panels for easier access to the wire holders/separators next time. They're held in place with 10 mm bolts.
Old Jul 31, 2007 | 11:33 AM
dclafleur's Avatar
dclafleur
I probably will next time, of course I found that advice after I had bloody knuckles Even doing that I still label each wire with its cylinder number with masking tape. Takes five seconds a wire, pulls off quickly and stays out of the way. Of course I'm one of those nuts who has labels on every damn bolt and piece I touch. That way I know what the big pile of "extras" I have in my garage is after I reassemble everything.
