VATS Key Problem?
Old Aug 7, 2007 | 10:31 PM
Chewch87's Avatar
Chewch87
Default VATS Key Problem?
On occassion I go to start my 87 and she won't start. Everything lights up ....nothing turns over...no clicking...lights don't dim. I wait a few minutes and she will start but not always on the second attempt. The owners manual states to try another key....but It also states you have to wait 4 minutes to let the VATS reset.So I am not sure if both keys are shot. I assume both keys are original...they are not terribly worn down. Should I cough up the $30 bucks for a new Key????
Old Aug 7, 2007 | 10:53 PM
newbecorvetteguy's Avatar
newbecorvetteguy
Odds are it's not the key that's the problem, it's the contacts inside the lock cylinder that go bad. The options are to determine the vats code and replace the lock and key, buy a pre-made bypass kit for 20-some bucks, or build your own bypass for a couple bucks. I purchased the 20-some buck plug and play deal for mine.
Old Aug 7, 2007 | 11:04 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
There is a locksmith supply in Utah that sells vats keys for $3.50 plus ship. Try a new key first. I can't remember the name. Try a search here and Google. The vats bypass cable solved my problem. In my case it wasn't the key.
Old Aug 7, 2007 | 11:23 PM
ZRWON's Avatar
ZRWON
Here's another solution for you to consider: If your key code is 13 (7.5 K ohms resistance), I have a VATS by-pass unit purchased from Ecklers for $32 including S&H. It's brand new with all documentation and easy installation instructions. I sold the Vette before I got the unit installed. This system solves VATS problems/frustrations permanently. I'll sell it for $20 including shipping via USPS Prority Mail.
Old Aug 7, 2007 | 11:30 PM
jfb's Avatar
jfb
If the pellet contacts in your spare ign key look in better condition than your everyday key, I doubt a new key is going to fix your problem. Another thing to try when it won't start is to bypass the clutch safety switch (gear selector switch at base of gear lever) with a jumper and measure the voltage on the jumper when you attempt a crank. If you have 12v and no cranking, then you have a battery connection, battery, or a starter problem. If no 12v, then most likely you have intermittent connection to the pellet inside the ign lock. You can prove this by removing the kick panel above the drivers feet and look for the 2 wires from behind the steering column that goes to a 2 pin connector and unplugging the connector. Insert your key in the ign and measure the resistance across the wires from the steering column. It should measure the same as the pellet and it must be within 4% of the assigned resistance value. You can temporarily bypass VATS until you can schedule the ign lock replacement by clipping a fixed resistor the same value as your pellet across the 2 pin socket from the wiring harness. You can use a 1/4 watt 5% resistor from Radio Shack, but it must be within 4% of the assigned value or at least the same value as your pellet. Don't permanently bypass VATS because 99% of thefts are done by bashing the column and jumping the ignition. I used a fixed resistor on my 87 about 6 years ago and had the lock replaced and haven't had a problem since and I drive my 87 everyday.
Old Aug 8, 2007 | 12:35 AM
93*Corvette's Avatar
93*Corvette
Are you crazy?
Goto http://www.clksupplies.com/shop/inde...cPath=24_26_66
They are $3.25 each.
Old Aug 8, 2007 | 12:56 AM
vettowner1994's Avatar
vettowner1994
Originally Posted by 93*Corvette
Are you crazy?
How does a person find out what key code they have? I wouldnt mind getting a few extra's.
Old Aug 8, 2007 | 03:03 AM
ynk1121's Avatar
ynk1121
Listen for the hum of the fuel pump priming when you first turn the key to the on position. If you can hear it, it's not vats.
Get a multimeter and set it to measure the resistance.
CODE---------RESISTANCE IN OHMS
1------------402
2------------523
3------------681
4------------887
5------------1130
6------------1470
7------------1870
8------------2370
9------------3010
10-----------3740
11-----------4750
12-----------6040
13-----------7500
14-----------9530
15-----------11800
Old Aug 8, 2007 | 07:43 AM
newbecorvetteguy
1------------402
2------------523
3------------681
4------------887
5------------1130
6------------1470
7------------1870
8------------2370
9------------3010
10-----------3740
11-----------4750
12-----------6040
13-----------7500
14-----------9530
15-----------11800
Or take the key to the parts dept of your local GM dealer if it's handy. They'll tell you what it is too in case you don't have an ohm meter.
Old Aug 8, 2007 | 09:55 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Check to see if you have a stored code 46
http://members.shaw.ca/corvette86/Code%2046.pdf
Old Aug 8, 2007 | 12:57 PM
vettowner1994
1------------402
2------------523
3------------681
4------------887
5------------1130
6------------1470
7------------1870
8------------2370
9------------3010
10-----------3740
11-----------4750
12-----------6040
13-----------7500
14-----------9530
15-----------11800
Measuring across the chip I am getting an 11.82? I take it that would be a 11800?
Old Aug 8, 2007 | 01:05 PM
All2kool's Avatar
All2kool
The VATS is controlled by the ECM. Changing locks (PITA) will only work if the key stays the same VATS number, of which there are 15 possibilities. Disabling your VATS would be a solution. Go to a locksmith, they will test your key and be able to sell you a module to disable VATS. Remove the underdash panel on the driver side. You should easily spot a two-wire grouping, I believe yellow/orange/green and white, just to the right of the steering column (as it was on my 1989 TA). You should notice that it disconnects in the middle. Disconnect it, insert the module you got from the locksmith into the wire going towards the firewall. Voila, VATS is now disabled. The module will cost you $25 - and your car will never not start because of VATS. It actually took me longer to remove the underdash panel than it did to locate the wire and insert the module.
As for the security feature of VATS being disabled, only you will know. A car thief will likely pass your car by for another, like a Camry or Honda.
Old Aug 8, 2007 | 01:09 PM
BADDUCK's Avatar
BADDUCK
Take it to a dealer parts counter they will measure it for free.
Old Aug 8, 2007 | 02:31 PM
ZRWON's Avatar
ZRWON
YES: the numbers shown on the previous post are ~ mid range for each code. The acceptable range for key code 15 is 11328-12292 Ohms
resistance or 11.8K, or 11800
Old Aug 8, 2007 | 05:46 PM
vettowner1994
Thanks for the info!!
Old Aug 9, 2007 | 08:05 AM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
www.vatssucks.com
all the info you need right there.
Repairs or bypassing. Its all there, with pics.
Old Aug 9, 2007 | 11:19 AM
ZRWON's Avatar
ZRWON
Originally Posted by GIJoe
www.vatssucks.com
all the info you need right there. Repairs or bypassing. Its all there, with pics.
Great site. Thanks for posting and all your work. I've added it to my C4 "Favorites File" for the next time I might need to fight the battle of "won't start"
To VATS Key Problem?
Old Aug 9, 2007 | 11:57 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Or, as an alternative, you could find out why you're car REALLY isn't starting, other than crippling the VATS and posting the all to familiar "Got rid of VATS. still won't start" post. Are you getting a code, does the security light go out? 90% of the time it's either the nuetral/clutch switch, starter/solinoid, or ignition switch. The keys almost never go bad, they just get dirty......... How fitting is that, got an extra star on a VATS post!
Old Aug 9, 2007 | 05:14 PM
Chewch87's Avatar
Chewch87
Are you crazy?
NO...NOT CRAZY!!!...... It has been a good 15 years since I was raped at a GM service center.....I remember them charging me $25 bucks at that time. I figured they keys were the same price...hav not searched ebay for blanks. So thats good news that they are 3 bucks.
Old Aug 9, 2007 | 11:07 PM
93*Corvette
This color chart is for alot of things, you will find your VATS values on it...
