Mercon vs Dexron
Old Aug 8, 2007 | 12:24 AM
hthebeard's Avatar
hthebeard
Default Mercon vs Dexron
I am planning to have my atf changed. Is Mercon compatible with Dexron III which my owners manual says to use. I have been to two places sofar, and they want to put Mercon in it, but I know Mercon is for Ford and Dexron is for GM. I just want a pan drop and filter change, no flush. Thanks for any info.
Old Aug 8, 2007 | 12:26 AM
Demonic85's Avatar
Demonic85
Nope, they're different.
Old Aug 8, 2007 | 06:28 AM
timmy 93's Avatar
timmy 93
Just tell them what you want put in.They should not have a problem with that.{or do it yourself}not that hard to do.
Old Aug 8, 2007 | 11:13 AM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
Do it yourself. It's not difficult at all, just messy.
Old Aug 8, 2007 | 11:29 AM
myc4vette's Avatar
myc4vette
Old Aug 8, 2007 | 06:56 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Default consider buying at dealer, consider avoiding synthetic
hthebeard,
I've noticed that finding pure Dexron III is difficult, most seem to carry newer chemical compositions which are Dexron IV/Mercon (suposedly works with both).
Perhaps the places you talked to, were implying the combo products.
Reminder, sometimes a newer rating (e.g. III -> IV) is not better as its chemical composition might not be backward compatible (e.g. should not use synthetic in early C5 manual transmissions because of 'paper blocking rings, or DOT 4 brake fluid is some aspects is not compatible with/when DOT 3 is specified).
Alternatively, you might be able to buy the Dexron III from a dealer and have your local shop do the change with it...
Old Aug 8, 2007 | 09:49 PM
hthebeard's Avatar
hthebeard
Originally Posted by theadmiral94
hthebeard,
Thanks. I did find a shop that still carried Dexron III in bulk and when the tech pulled the pan everything looked very clean, like maybe it was serviced not too many miles ago. But it does shift a lot smoother now.
To Mercon vs Dexron
