Does this friggin' thing really do anything or does it just add to the clutter under the hood? I'm wondering if someone can send me a picture of their L98 with and without it. I won't be able to look at it until later...my job has some kind of web blocker installed and I can't seem to get any pictures anymore.
C4 of Year Winner (appearance mods) 2019
Originally Posted by vader86
Its there for startup emissions, it gets the cats cooking faster.
After the car goes to closed loop, it doesnt do much help.
Read (actually re-read) your site this weekend. I noted the computer goes closed loop after 5 minutes when cold (66 seconds when hot) -- independant of the AIR pump, O2 sensor, etc... A timer causes the switch. As noted, the AIR pump switches from manifold to CAT "heating" when the computer goes closed loop. So, what difference does it make if the AIR pump is there or not?
I'm guessing the O2 sensor doesn't "see" the cooler cat but it might not be as hot? I suppose the emissions would be a little higher right after switch-over without the hottest cat possible? Would the O2 sensor being cooler cause a temporary richer condition (on top of the cooler, less efficient cat)?
I've also seen the AIR helps heat the O2 sensor. If absent, how does that effect overall emissions/performance/etc....? What's the whole picture????
If you go for an emissions test, it probably won't pass the visibility test; meaning he'll be looking for it and if the pump's not there, you don't pass. But if you don't have emissions testing, removing the pump will do no harm whatsoever. If you look at my engine pictures, you'll see mine w/o the pump.
Thanks everyone. I'm not actually doing it for a performance gain, I just want to remove some of the clutter under the hood and make other things easier to work on... it sounds like a pretty bogus attempt at pollution control by our friends at GM. I already have long tubes and no pre cats, so inspection is already going to be a hassle but there's no "visual" so maybe I'll be ok.
By your profile, I assumed that you lived in California. I guess not if you don't have to worry about a visual inspection.
It's a good thing he doesn't live in Ca., for if he did, the smog ***** would have tossed a midget into the engine bay looking for any bolt that's not in emission compliance.
Sheesh, I failed emissions on my dd because a vacuum hose from the charcoal cannister was disconnected. Some emission controls are not only good for the environment but actually help your fuel economy. I saw an interesting hot rod magazine article, the guy did some step by step performance mods followed by dyno runs on his 04 GTO. One of the more interesting was only a 6 hp loss when he hooked up the catalytic converters. I dont think it hurt him too much as he ended up pushing the performance to over 600 hp. Pump gas and emissions legal.
On my 86 vette, I removed all the plumbing going to the smog pump, and taping up the wiring. Next project was to remove the smog pump and taking vanes out of it, cleaning it up, and reinstalling it. works as good as the pump eliminator and it don't cost anything at all.
