Overdrive
Old Aug 20, 2007 | 10:30 PM
Swift_Striker's Avatar
Swift_Striker
Default Overdrive
umm my overdrive is acting all kinds of funky. it likes to turn itself on.. a lot. the main time is when I shift from 1st to 2nd it will turn on, I hit the overdrive button and it turns off then 3rd gear shift works but sometimes the 4th gear shift it turns itself back on again. I turn it off and shift to 1st for a light, repeat. Now if I don't turn off OD in 2nd and 3rd it will turn off when I goto 4th.
I have the 4+3 early one with the overdrive on the button btw.
any thoughts?
Old Aug 20, 2007 | 11:23 PM
89 Bob L's Avatar
89 Bob L
What year car?
Old Aug 20, 2007 | 11:32 PM
Swift_Striker
it's a 1986
Old Aug 20, 2007 | 11:46 PM
The Beep's Avatar
The Beep
It sounds like you have the button in the shift ****. On the bottom side of the shifter is a switch. You might check to see if the switch is intermittant or something wrong with the actuator. I moved mine to a toggle switch on the console and it works great.
Old Aug 21, 2007 | 04:47 AM
Swift_Striker
how hard was the toggle switch move, it sounds like your right so I'll fiddle with it but the toggle switch may be simpler.
Old Aug 21, 2007 | 09:11 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Check out the relay, the wire insulation shrinks back and will allow a possible intermittent short.
Here is some daignostics from my 86 manual. http://members.shaw.ca/agent86/Overd...iagnostics.pdf
Old Aug 21, 2007 | 10:29 AM
dclafleur's Avatar
dclafleur
While you're at it change the OD fluid and filter, unless you've done it recently. The seal around the pan goes bad from sitting in atf all the time and they tend to be low on fluid. doubt that would cause the switching on condition but it was the cause of my problems with the OD acting goofy.
Old Aug 21, 2007 | 11:25 AM
Swift_Striker
thanks for the tip but i forgot to mention I got the whole overdrive serviced while the new clutch was going in...
I'll look for that wire I think.
Old Aug 21, 2007 | 02:44 PM
matrix040's Avatar
matrix040
I had the same problem, turned out to be a loose connection.
Resoldered it and it's fine now.
Old Aug 21, 2007 | 03:27 PM
corvettedan22's Avatar
corvettedan22
http://www.theforumlounge.com/thread...ification.html
Old Aug 21, 2007 | 04:13 PM
Yellow2015's Avatar
Yellow2015
There are so many parameters that control the OD unit........speed, temp etc that it can be tough to nail down a problem. I just picked mine up last week after having the OD completely rebuilt. Mechanically it's great but it still goes into OD the first time the engine temp hits 123. Once I trun it off it works fine.
There is a thread here in archives that details how to turn it into a completely manual OD that you may find interesting. Other then that I'd have to agree about the relay.
Old Aug 21, 2007 | 05:05 PM
Swift_Striker
thanks for all the help, time to go look at it thoroughly
To Overdrive
