Oops ! Wheel locks key is lost !
Old Aug 28, 2007 | 06:48 PM
Calderone's Avatar
Calderone
Default Oops ! Wheel locks key is lost !
Damn,removing my 87 wheel nuts i found out that just one wheel have a different wheel lock nut !!!
OH NO ! The key is nothing like the others and i don't have it , i looked for it under the seats,on the rear compartments,everywhere and Nothing ! How can i remove that damn nut ?????????
Please i need some tips !
Old Aug 28, 2007 | 06:54 PM
Da Mail Man's Avatar
Da Mail Man
.....there are a few threads on this in the SEARCH section of the forumn.......anyway, take a chisel or a die grinder and "cut" a notch into the face of the lock........insert a "stout" screwdriver and turn..............also, you can sacrifice a socket and smash it onto the socket and attempt to remove it like that....(i am not sure what type of locks you have).....
Old Aug 28, 2007 | 06:55 PM
The Green Hornet's Avatar
The Green Hornet
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
Find a socket that almost fits and pound it on the rest of the way.
Old Aug 28, 2007 | 07:15 PM
Kinkajou's Avatar
Kinkajou
The Green Hornet Find a socket that almost fits and pound it on the rest of the way.
I have been told that this is the way that thieves can remove your wheels in no time.
So it must work very well.
They also use vise grips if the wheel design allows it, and if that will not work you can always weld a piece of metal and then remove it.
Old Aug 28, 2007 | 07:33 PM
rlatlarson's Avatar
rlatlarson
Hate to suggest it, but I took mine to the local Chevy dealership. They either had a "generic" one-key-fits-all socket or they have a full set of keys on hand for such instances.
I ended up buying a new set with a key from one of the catalog companies. Now the key sits in the center console.
Old Aug 28, 2007 | 07:50 PM
Da Mail Man
.....like i said! ....my 88 has a lug cover that covers all the lugs and uses a recessed lock so, it would have to be either drilled out or that "cut a slot deal" i mentioned....
Old Aug 28, 2007 | 08:20 PM
jimmyu2's Avatar
jimmyu2
I have to add my 2 cents
When I got my 89 Vert...I could not get the locks loosened. Someone had tightened them so tight, and had stripped the special wrench..(it was almost useless). After struggleing with them trying to get them loose, I was able to loosen the special bolts eventually. Now (I have "new" replacements) when I install them I turn them in to the point where they "bottom out" and then add just a little bit more. I've discovered that there is no need to "lean on them" Bottom 'em out then add a bit more torque. This will save your lock bolt, and your special wrench.
Old Aug 28, 2007 | 08:53 PM
I’m Z one's Avatar
I’m Z one
2022 Corvette of the Year Finalist -- Modified
2021 C5 of the Year Winner - Modified
This is all you need ->http://www.sears.com/shc/s/p_10153_1...=stripped+nuts
Old Aug 28, 2007 | 09:00 PM
Road Agent's Avatar
Road Agent
Old Aug 28, 2007 | 09:56 PM
Mekanic's Avatar
Mekanic
Using instructions I found here I used a 21mm socket ( I think it was 21 check first.) then pounded it on the nut with a 3 pound sledge.
The points in the socket cut into the threads used to hold the plastic cap on, and off it will come. Worked like a charm.
Old Aug 28, 2007 | 10:04 PM
frankburns's Avatar
frankburns
Default Wheel locks
Used a socket that was just a tad smaller, 19mm or 21mm can't remember, just had to tap it on with a roofing hammer, then just used a braker bar. Took 10 minutes to remove all 4. I also used a heavy impact socket that went undamaged. After each wheel I put the lug in the vice and used said hammer to knock the socket off.
Old Aug 28, 2007 | 10:05 PM
VettBrat's Avatar
VettBrat
When I bought my 86 it did not have the key for the wheels. I took it to a tire shop and they removed all 4 in about 5 minutes. Didn't charge me anything.
Old Aug 28, 2007 | 10:39 PM
NASCAR314's Avatar
NASCAR314
Yes, good tire shops can do it as well as a dealer, FREE is hard to get!
I bought a car at auction, could not locate lug key, had a tire shop remove them and replaced with normal lug nuts, charged me $7.50 per wheel, which is well worth it.
Old Aug 29, 2007 | 08:11 AM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
Sounds like you need an "Easy Out" socket
its a socket with teeth in it for just such occasions.
Old Aug 29, 2007 | 09:14 AM
dclafleur's Avatar
dclafleur
If you can find a friendly local shop it's the way to go, took them a minute to get mine off. They also don't mind me looking over their shoulder when they lift the car and watching them work when they remove and replace the wheels. They got my business by providing good service, and kept it by meeting my demands (and having a darned good price too)
To Oops ! Wheel locks key is lost !
