Tomz Wheels
Old Aug 30, 2007 | 12:50 PM
redwing76's Avatar
redwing76
Originally Posted by JEFNLSA
Base 96's came w/ 8.5's up front & 9.5's on the rear.
I had 9.5's all around but eventually switched to 11" rears for the wider profile out back. Gives it a wider stance which I like but tires for 11's are much harder to come by...either very pricey or very cheap...not many options. 9.5's all around will allow you to rotate front to back...and many more tire options are available to you. You can go w/ 285's all around for a meatier look...which is what I had before I went to 11's. It's really up to you which way to go but you can get a set of 9.5 fronts & 11" rears from Tomz for close to the same price as 4-9.5's...so price isn't really a factor. Do you want the big meats on the rear or not? Either way you'll love it...keep in mind the 11's w/ 315's do stick out the wheel wells just a tad.
