Rad Question??
Old Aug 29, 2007 | 02:01 PM
2fast4u_vette's Avatar
2fast4u_vette
Default Rad Question??
I was doing some checking up on my fluids and I didnt noticed before but theres a nipple coming out of the Rad that looks like some wire is suppose to go in there. Can someone varify that for me? Please check out the link below for picture. Thanks
http://s92.photobucket.com/albums/l1...urrent=rad.jpg
Old Aug 29, 2007 | 02:04 PM
arandy's Avatar
arandy
St. Jude Donor '08
Low coolant sensor.
Old Aug 29, 2007 | 02:21 PM
2fast4u_vette
Originally Posted by arandy
Low coolant sensor.
Oh, so does anything need to be plugged into it? Let me know thanks.
Old Aug 29, 2007 | 02:28 PM
InHot's Avatar
InHot
It is a sensor. It is not wireless. It requires a wire. If you are not getting a low coolant light, someone probably removed the bulb.
Old Aug 29, 2007 | 02:50 PM
2fast4u_vette
Hmmm so how can you tell? I am not getting any low coolant light on my 84 vette. Where do I find the wire in the engine bay? I only had this car for a year and I am tottally a Newbie. Thanks
Old Aug 29, 2007 | 03:56 PM
vettowner1994's Avatar
vettowner1994
The clamp on the sensor amuses me.I have never seen a low coolant sensor clamped on. Usually they are threaded into the radiator as far as I knew. You have to have a wire under there somewhere that isnt connected and is long enough to reach that area. Probably coming out of a wire loom close by.
Old Aug 29, 2007 | 04:48 PM
2fast4u_vette
Do any of you guys have a picture of your wire going to this sensor so I can get an idea where to find the wire. Thanks
Old Aug 29, 2007 | 11:57 PM
2fast4u_vette
Bump
Old Aug 30, 2007 | 02:15 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
It is usually a green wire with a funny looking thing on the end that is a push in and lock into the radiator after you remove the push in and lock that is in the radiator now.The wire should e around the pass side up front where the head lights are.I would believe someone cut it off because they coundn't figure out what it was.
To Rad Question??
